I have a service that records rtsp stream, written in python, i’m using ffmpeg and opening a thread that capture the stream.
i’ve used journalctl --no-pager -a and saw that i’m getting an error:
kernel: smsc95xx 2-1.1:1.0 cam1: kevent 2 may have been dropped
i’ve read that i need to change vm.min_free_kbytes to 32768.
Is that a setting i’m able to change using network manager?
Could you please give us more details on what you are trying to accomplish here?
Are you trying to setup a camera? Here are some instructions that may be useful https://www.balena.io/fin/1.1/docs/developers/#Dual-camera-mode.
this is the flow:
we’ve set up two additional network interfaces.
i’m just running an ffmpeg command that records a camera on this interface (without any transcoding), and after 5 minutes, both threads was closed, and the error i see is what i’ve written (the error from journalctl --no-pager -a)
Thanks for the extra context.
You can change the vm.min_free_kbytes sysctl parameter, which appear tunable as part of compose 2.1: sysctls in docker-compose.yml.
Please let us know if this helps.
thanks.
this is my current compose file, but the service is not starting.
am i missing something?
version: ‘2.1’
volumes:
resin-data:
services:
recordingservice:
container_name: recordingservice
build:
context: ./recordingservice
expose:
- "49525"
volumes:
- 'resin-data:/data'
privileged: true
sysctls:
vm.min_free_kbytes: 32768
Hi there,
A few questions to see if I can pin the issue down:
- How are you building/deploying the app? Are you using
balena push?
- You say the service is not starting, is there any error message?
You could also enable support access and let me know the device UUID (in a private message), and I’ll take a look.
Phil
