I have a couple of Pi Spotify Connect nodes around the house, these have been working fine until I installed Pi-Hole. Reading around it could be that Pi-Hole is blocking some required domains for Spotify to function:
For the BalenaSound part of this issue, is that correct? That Spotify needs some domains to be whitelisted?
The Pi-Hole part of this then, how can I incorporate that list into Balena Pi-Hole, such that it maintains upstream updates [git pull], but also so that I don’t have to manually input all those addresses through the Pi-Hole web interface.
Thanks in advance!
