I am trying to set up open-balena according to the getting started guide and I run into a problem after starting the docker service:
In this step:
./scripts/quickstart -U <email@address> -P <password> -d mydomain.com
I omitted the -d mydomain.com command for now, because I just wanted to test the setup process locally, before moving it to an server instance. My guess is, that this is not related to my error.
Shortly after, when proceeding with this step:
systemctl start docker
./scripts/compose up -d
I run into the following error (is this maybe because Ubuntu 18.02 and Debian Bullseye handle cgruops differently?):
ERROR: for openbalena_haproxy_1 Cannot start service haproxy: driver failed programming external connectivity on endpoint openbalena_haproxy_1 (...): Error startin userland proxy: listen tcp4 0.0.0.0:80: bin: address already in use
ERROR: for haproxy Cannot start service haproxy: driver failed programming external connectivity on endpoint openbalena_haproxy_1 (...): Error starting userland proxy: listen tcp4 0.0.0.0:80: bin: address already in use
ERROR: Encountered errors while bringing up the Project
