Greetings…
I have been interested in playing around with openBalena over the past month or so. My environment is a System76 Meerkat running pop_os on my local network. I initially was able to get the server running after tweaking the mdns setup. However, couldn’t ever get any of my client boards to successfully connect. (a couple of Pi’s, a RevolutionPI and a Jetson Nano). I concluded this may have something to do with .local stuff and my network, so I decided to try the DNS route.
(Note that at this point I updated the OS on the openBalena box to 21.10 from 20.04)
I setup DNS entries on one of my personal domains to point to the “home network” IP of the openBalena box. I can ping all of the various services with no problem, i.e. api.openbalena.myactualdomain.com. I deleted the openBalena and docker images directories to get a clean start and after download ran…
./scripts/quickstart -U someemailaddr -P somepwd -d openbalena.myactualdomain.com
Config files all look fine, however after startup api, s3, vpn and registry all terminate immediately with exit code 255 (I think code is a docker thing). Haproxy, cert, redis and db all continue to run.
Running ‘./scripts/compose logs api’ only yields the line…
Systemd init system enabled
Running ‘./scripts/compose exec api journalctl -fn100’ doesn’t do anything since the container is not running
At this point I fell back to the openbalena.local route that worked before but now it is yielding the same result with the 4 services terminating immediately.
A few other things I’ve checked…
- nothing running on base system using key ports
- firewall is not active
- can ping to all names from local laptop and server box (api, s3, etc)
- the box is not running anything else so should have plenty of resources
So, any thoughts or other tips. Seems like there must be a way to determine why these services are terminating. Is 21.10 Ubuntu possibly an issue?
Thanks!!
