Hi, I am currently testing out openBalena for our project and was wondering if it can be run with an apache installation on the same host. When I start the docker container I get the following error message for ha_proxy:
ERROR: for openbalena_haproxy_1 Cannot start service haproxy: driver failed programming external connectivity on endpoint openbalena_haproxy_1 (2466a1839d2dcc7d4a851c4a6afc8694e8601d174a0a3e28c9f621c5f5c80c55): Error starting userland proxy: listen tcp 0.0.0.0:443: bind: address already in use
ERROR: for haproxy Cannot start service haproxy: driver failed programming external connectivity on endpoint openbalena_haproxy_1 (2466a1839d2dcc7d4a851c4a6afc8694e8601d174a0a3e28c9f621c5f5c80c55): Error starting userland proxy: listen tcp 0.0.0.0:443: bind: address already in use
ERROR: Encountered errors while bringing up the project.
Which is obvious, as the apache service is already bound to port 80 and 443.
Probably, I need to bring my websites into docker containers to run them with openBalena. I’ve seen that there is a possibility with nginx-proxy or something like that. However, I am completely new to the docker and openBalena world and would be pleased, if somebody could provide me with some straight-forward information before I end up off the track. ;))
Many thanks in advance!
Pievee
