Running an instance of open-balena
Hi , i am trying to run an instance of open balena , but I an running into a few blockers,here is my terminal output:::tl@tl-HP-EliteBook-840-G3:~$ sudo su balena
[sudo] password for toel:
balena@tl-HP-EliteBook-840-G3:/home/tl$ cd ~/open-balena
balena@tl-HP-EliteBook-840-G3:~/open-balena$ make up
make[1]: Entering directory ‘/home/balena/open-balena’
BALENARC_NO_ANALYTICS=1
DNS_TLD=mydomain.com
ORG_UNIT=openBalena
PRODUCTION_MODE=true
SUPERUSER_EMAIL=admin@mydomain.com
VERBOSE=false
make[1]: Leaving directory ‘/home/balena/open-balena’
[+] Running 0/0
[+] Running 0/6-manager Building 0.1s
⠸ Service cert-manager Building 0.4s
⠸ Service sut Building 0.4s
⠸ Service haproxy Building 0.4s
⠸ Service haproxy-sidecar Building 0.4s
⠸ Service dut Building 0.4s
[+] Building 3.7s (62/62) FINISHED docker:default
=> [sut internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 986B 0.0s
=> [haproxy-sidecar internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 149B 0.0s
=> [haproxy internal] load build definition from Dockerfile 0.1s
=> => transferring dockerfile: 182B 0.0s
=> [tag-sidecar internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 129B 0.0s
=> [dut internal] load build definition from Dockerfile 0.1s
=> => transferring dockerfile: 309B 0.0s
=> [cert-manager internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 131B 0.0s
=> [cert-manager internal] load metadata for docker.io/balena/cert-manag 3.2s
=> [haproxy-sidecar internal] load metadata for Docker Hub Container Image Library | App Containerization 3.2s
=> [tag-sidecar internal] load metadata for Docker Hub Container Image Library | App Containerization 3.2s
=> [sut internal] load metadata for Docker Hub Container Image Library | App Containerization 3.2s
=> [haproxy internal] load metadata for docker.io/balena/open-balena-hap 3.2s
=> [dut internal] load metadata for docker.io/qemux/qemu-docker:6.14 3.2s
=> [haproxy auth] balena/open-balena-haproxy:pull token for registry-1.d 0.0s
=> [haproxy-sidecar auth] library/docker:pull token for registry-1.docke 0.0s
=> [cert-manager auth] balena/cert-manager:pull token for registry-1.doc 0.0s
=> [dut auth] qemux/qemu-docker:pull token for registry-1.docker.io 0.0s
=> [tag-sidecar auth] library/bash:pull token for registry-1.docker.io 0.0s
=> [sut auth] library/ubuntu:pull token for registry-1.docker.io 0.0s
=> [sut internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [haproxy internal] load .dockerignore 0.0s
=> [haproxy-sidecar internal] load .dockerignore 0.0s
=> [cert-manager internal] load .dockerignore 0.0s
=> [tag-sidecar internal] load .dockerignore 0.0s
=> [dut internal] load .dockerignore 0.0s
=> [sut 1/7] FROM Docker Hub Container Image Library | App Containerization 0.0s
=> [sut internal] load build context 0.0s
=> => transferring context: 60B 0.0s
=> [haproxy 1/2] FROM docker.io/balena/open-balena-haproxy:v4.3.2@sha256 0.0s
=> [haproxy internal] load build context 0.0s
=> => transferring context: 33B 0.0s
=> [haproxy-sidecar 1/3] FROM Docker Hub Container Image Library | App Containerization 0.0s
=> [haproxy-sidecar internal] load build context 0.0s
=> => transferring context: 31B 0.0s
=> [tag-sidecar internal] load build context 0.0s
=> [tag-sidecar 1/2] FROM Docker Hub Container Image Library | App Containerization 0.0s
=> [cert-manager 1/2] FROM docker.io/balena/cert-manager:0.2.3@sha256:e1 0.0s
=> [dut 1/4] FROM docker.io/qemux/qemu-docker:6.14@sha256:f233acd30696e2 0.0s
=> CACHED [haproxy 2/2] COPY haproxy.cfg /usr/local/etc/haproxy/haproxy. 0.0s
=> CACHED [sut 2/7] RUN apt-get update && apt-get install -y --no-instal 0.0s
=> CACHED [sut 3/7] RUN curl -fsSL https://get.docker.com | sh 0.0s
=> CACHED [sut 4/7] WORKDIR /opt 0.0s
=> CACHED [sut 5/7] RUN set -x; arch=$(uname -m | sed ‘s/86_64/64/g’) 0.0s
=> CACHED [sut 6/7] COPY functions balena.sh /usr/sbin/ 0.0s
=> CACHED [sut 7/7] WORKDIR /balena 0.0s
=> [dut internal] load build context 0.0s
=> [cert-manager internal] load build context 0.0s
=> [haproxy] exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:33864e7ea1b21a427596653bc83773f630d7cfc2c3847 0.0s
=> => naming to Docker Hub Container Image Library | App Containerization 0.0s
=> [sut] exporting to image 0.0s
=> => writing image sha256:28f48709b3e1318e49765d6a699dcedbb35eb511dfe5a 0.0s
=> CACHED [tag-sidecar 2/2] COPY balena.sh /usr/local/bin/balena.sh 0.0s
=> CACHED [cert-manager 2/2] COPY *.json /opt/ 0.0s
=> CACHED [haproxy-sidecar 2/3] COPY balena.sh /usr/local/bin/balena.sh 0.0s
=> CACHED [haproxy-sidecar 3/3] RUN apk add --no-cache bash 0.0s
=> [tag-sidecar] exporting to image 0.0s
=> => writing image sha256:12378bf569a7f39b02719738541ff1d87511f8e816f52 0.0s
=> [haproxy-sidecar] exporting to image 0.0s
=> => writing image sha256:d477aa0a100bbf8674836fb4bba7a140e598260790216 0.0s
=> CACHED [dut 2/4] RUN apt-get update && apt-get install -y --no-instal 0.0s
=> CACHED [dut 3/4] COPY balena.sh /usr/sbin/ 0.0s
=> CACHED [dut 4/4] WORKDIR /balena 0.0s
=> [cert-manager] exporting to image 0.0s
=> => writing image sha256:139dc3c4b5c5bcba36a398584b35eddf449922e321365 0.0s
=> [dut] exporting to image 0.0s
=> => writing image sha256:17c7b4fc9b67159e1329d6dc30ce8b09d62210e68e08c 0.0s
[+] Running 20/20docker.io/library/open-balena-dut 0.0s
:heavy_check_mark: Service cert-manager Built 3.8s
:heavy_check_mark: Service sut Built 3.8s
:heavy_check_mark: Service haproxy Built 3.8s
:heavy_check_mark: Service haproxy-sidecar Built 3.8s
:heavy_check_mark: Service dut Built 3.8s
:heavy_check_mark: Service tag-sidecar Built 3.8s
:heavy_check_mark: Container b33320797c1a_open-balena-balena-ca-1 Started 2.2s
:heavy_check_mark: Container open-balena-s3-1 Started 2.2s
:heavy_check_mark: Container open-balena-cert-manager-1 Started 3.4s
:heavy_check_mark: Container c11a95e3ca66_open-balena-db-1 Started 2.2s
:heavy_check_mark: Container 369dcb8c1240_open-balena-redis-1 Started 2.2s
:heavy_check_mark: Container open-balena-dut-1 Started 2.2s
:heavy_check_mark: Container open-balena-registry-1 Started 3.4s
:heavy_check_mark: Container 07977cd6b7d9_open-balena-haproxy-sidecar-1 Started 2.3s
:heavy_check_mark: Container open-balena-tag-sidecar-1 Started 1.9s
:heavy_check_mark: Container open-balena-docker-1 Started 2.1s
:heavy_check_mark: Container open-balena-sut-1 Started 2.1s
:heavy_check_mark: Container open-balena-haproxy-1 Started 2.3s
:heavy_check_mark: Container open-balena-api-1 Started 3.6s
:heavy_check_mark: Container open-balena-vpn-1 Started 4.9s
…^Cmake[1]: *** [Makefile:72: wait] Interrupt
make: *** [Makefile:82: up] Interrupt
balena@tl-HP-EliteBook-840-G3:~/open-balena$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6eb3581a168b balena/open-balena-vpn:v11.30.83 “/usr/bin/entry.sh” 13 hours ago Up 5 minutes (unhealthy) 80/tcp, 443/tcp, 3128/tcp open-balena-vpn-1
bdafff2375b9 balena/open-balena-api:v34.4.8 “/usr/bin/entry.sh” 13 hours ago Up 5 minutes (unhealthy) 80/tcp open-balena-api-1
fcab1296f626 open-balena-cert-manager “/bin/bash -c /usr/l…” 13 hours ago Up 5 minutes 80/tcp, 443/tcp open-balena-cert-manager-1
45f761a56037 balena/open-balena-registry:2.41.23 “/usr/bin/confd-entr…” 13 hours ago Up 5 minutes (unhealthy) open-balena-registry-1
8ec2bcd42ab1 open-balena-haproxy “docker-entrypoint.s…” 13 hours ago Restarting (1) 31 seconds ago open-balena-haproxy-1
7ecac6d4515f balena/open-balena-db:6.0.0 “/balena-entrypoint.…” 20 hours ago Up 5 minutes (healthy) 5432/tcp c11a95e3ca66_open-balena-db-1
2932aff4dfbe balena/ca-private:0.0.15 “/bin/bash -c /usr/l…” 20 hours ago Up 5 minutes (healthy) 8888/tcp b33320797c1a_open-balena-balena-ca-1
8bbb3efd2468 balena/open-balena-s3:2.28.67 “/usr/bin/entry.sh” 20 hours ago Up 5 minutes (healthy) 80/tcp open-balena-s3-1
73377bff6f7d redis:7.4-alpine “docker-entrypoint.s…” 20 hours ago Up 5 minutes (healthy) 6379/tcp 369dcb8c1240_open-balena-redis-1
f4c35422ad70 open-balena-haproxy-sidecar “dockerd-entrypoint.…” 20 hours ago Up 4 minutes 2375-2376/tcp 07977cd6b7d9_open-balena-haproxy-sidecar-1
06df22546b5d docker:dind “/bin/sh -c 'set -x\n…” 20 hours ago Up 5 minutes (healthy) 2375-2376/tcp open-balena-docker-1
balena@tl-HP-EliteBook-840-G3:~/open-balena$ docker compose logs > error.txt
How can I fix this unhealthy containers and have my server up and running ?
It sounds to me like you didn’t set DNS_TLD to an actual domain you own?
Make sure you have it pointing to an actual server, and that the relevant ports are open.
It has been a while since I last played around with openBalena, but maybe that’s what’s tripping things up.
Judging from docker-compose.yml, you need TCP ports 80, 443 and 1936
Hello @Toel,
Do you try to use this ansible playbook to setup your open balena instance and admin dashboard ?
Maybe, this project can help you: open balena deployment
I do not think that will work anymore. It looks like this playbook still uses scripts to build everything. However openBalena has removed the scripts folder since v4.0.0.0
