oops! looks like the flash failed..
Mon May 16 2022 10:42:38 GMT+0800 (中国标准时间) Validation error ({“image”:{“size”:9734053888,“blockmappedSize”:8721048576,“compressedSize”:8583011708,“hasMBR”:true,“path”:“C:\Users\XYG\Downloads\macOS Catalina 10.15.4(19E266) Installer for Clover 5107 and WEPE Support UEFI and MBR.dmg”,“blocks”:[{“checksumType”:“crc32”,“checksum”:“925419c6”,“blocks”:[{“offset”:0,“length”:512}]},{“checksumType”:“crc32”,“checksum”:“4330dfe3”,“blocks”:[{“offset”:512,“length”:512}]},{“checksumType”:“crc32”,“checksum”:“c8b4a939”,“blocks”:[{“offset”:1024,“length”:16384}]},{“checksumType”:“crc32”,“checksum”:“3b7783e0”,“blocks”:[{“offset”:17408,“length”:209715200}]},{“checksumType”:“crc32”,“checksum”:“7aceb716”,“blocks”:[{“offset”:209732608,“length”:203840512},{“offset”:414859264,“length”:16384}]},{“checksumType”:“crc32”,“checksum”:“d926d2e7”,“blocks”:[{“offset”:734038016,“length”:25448448},{“offset”:874829824,“length”:11534336},{“offset”:1001711616,“length”:8270458880},{“offset”:9599818240,“length”:512}]},{“checksumType”:“crc32”,“checksum”:“c8b4a939”,“blocks”:[{“offset”:9734036992,“length”:16384}]},{“checksumType”:“crc32”,“checksum”:“8d64a213”,“blocks”:[{“offset”:9734053376,“length”:512}]}],“partitions”:[{“offset”:17408,“size”:209715200,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“3E132DB3-5F03-4E62-AE56-B2589C909217”,“name”:“EFI System Partition”,“index”:1},{“offset”:209732608,“size”:524305408,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“A3807392-C662-448B-808F-C214675AB173”,“name”:“disk image”,“index”:2},{“offset”:734038016,“size”:8865781248,“type”:“48465300-0000-11AA-AA11-00306543ECAC”,“guid”:“1F9B68A2-0AE3-44C8-A8AC-42424330DE59”,“name”:"",“index”:3}],“extension”:“dmg”},“drives”:[{“size”:31004295168,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive2",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive2",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:“Kingston DataTraveler 3.0 USB Device”,“isUAS”:false,“partitionTableType”:“gpt”}],“driveCount”:1,“uuid”:“40c6290b-df27-4887-bbfd-7568d452c01a”,“flashInstanceUuid”:“40c6290b-df27-4887-bbfd-7568d452c01a”,“sample”:0.1,“applicationSessionUuid”:“e597013f-94e4-4e20-bf31-05bafabf349a”,“flashingWorkflowUuid”:“73ae592f-c70b-4850-a438-665929955333”})
Hi, can you please share what a) image you were trying to flash b) the operating system of your computer and c) the version of balenaEtcher.
a) macOS Catalina 10.15.4 b) Windows 10 professional workstation
c) 1.7.9
Hi, I’m not seeing an error. Were you able to flash successfully, but just weren’t able to install the OS? I know installations of MacOS on non-Apple hardware can be tricky (as I’ve done it myself).
Thank you! I think i found the problem. Maybe my Kingston USB flash disk is … fake …
I am able to flash successfully. Just can not validate. But i installed macOS successfully!
