Balena reaches 99% in verification-and then says flash error..
I’m using the olarila .raw macos images (mojave in this case-latest-7.8 gigs) and used 5 different versions of balenaetcher, including the latest one. The full ones, 32 bit ones, 64 bit ones and the portable exes. I’m on Win10. Haven’t tried it with linux yet. I’ve tried it with big sur and sonoma images, and it worked. With the same pendrive (sandisk-64 gigs, though store brought it does the Bootable job well) I’m trying to flash mojave. It reaches ~99% in validation and then it throws me the error. I’ve re-downloaded the image with, without parallel downloading and a download manager. All failed. When inspected, the partitions check out, it boots and all, but when installing macos it gives me an error, or gets stuck at “2 minutes remaining”. Nothing wrong with my EFI or computer.
I would’ve sent the logs but I’m not around my laptop now. Usb doesn’t seem like it’s failing. Even so I chkdsk ed it, and disk part cleaned it. Gpt scheme.
This is part of my hackintosh project. Don’t judge me. Don’t.
Help appreciated, even more so if faster…
