I’m having trouble getting bluetooth (intel 8265ac) to work on the xavier.
I see these messages in dmesg
[ 141.047251] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
On the balena host os:
root@62c3252:~# systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/bluetooth.service.d
└─bluetooth.conf
Active: active (running) since Tue 2020-04-21 00:23:56 UTC; 14min ago
Docs: man:bluetoothd(8)
Main PID: 2025 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
Memory: 1.8M
CGroup: /system.slice/bluetooth.service
└─2025 /usr/libexec/bluetooth/bluetoothd --experimental
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
root@62c3252:~# rfkill list
0: bluedroid_pm: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
root@62c3252:~# journalctl -u bluetooth
-- Logs begin at Tue 2020-04-21 00:27:33 UTC, end at Tue 2020-04-21 00:37:56 UTC. --
-- No entries --
I’ve also tried the following app with no luck.
