[Axios v1.7.1] Transitional option ‘clarifyTimeoutError’ has been deprecated since v1.0.0 and will be removed in the near future
[Axios v1.7.1] Transitional option ‘forcedJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
[Axios v1.7.1] Transitional option ‘silentJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
2021-12-07 09:02:07.698 balenaEtcher[48135:1962839] +[NSXPCSharedListener endpointForReply:withListenerName:]: an error occurred while attempting to obtain endpoint for listener ‘ClientCallsAuxiliary’: Connection interrupted
{“message”:“certificate has expired”,“stack”:“Error: certificate has expired\n at TLSSocket.onConnectSecure (_tls_wrap.js:1497:34)\n at TLSSocket.emit (events.js:315:20)\n at TLSSocket._finishInit (_tls_wrap.js:932:8)\n at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:706:12)”,“config”:{“url”:“https://balena.io/etcher/static/config.json",“method”:“get”,“headers”:{“Accept”:"application/json, text/plain, /”,“User-Agent”:“axios/1.7.1”},“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“responseType”:“json”,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false}},“code”:“CERT_HAS_EXPIRED”}
(node:48149) Electron: Loading non-context-aware native module in renderer: ‘/Applications/balenaEtcher.app/Contents/Resources/app/generated/modules/@balena.io/usb/build/Release/usb_bindings.node’. This is deprecated, see [Discussion] Requiring Native Modules in the Renderer Process to be NAPI or Context Aware · Issue #18397 · electron/electron · GitHub.
(Use balenaEtcher Helper (Renderer) --trace-warnings ... to show where the warning was created)
ready-to-show: 1.685s
Hello there,
This is a known issue that has been fixed in the latest versions of etcher. Please try updating your etcher version and let us know if it’s still an issue.
Cheers,
Nico.
