I am running on MacBook Pro (15-inch, 2017) macOS Monterey 12.0.1
balenaEtcher 1.7.0
I have tried more than 10 different img to two different micro SD and all failed.
Failed to load resource: net::ERR_FILE_NOT_FOUND
gui.js:51687 {“message”:“certificate has expired”,“stack”:“Error: certificate has expired\n at TLSSocket.onConnectSecure (_tls_wrap.js:1497:34)\n at TLSSocket.emit (events.js:315:20)\n at TLSSocket._finishInit (_tls_wrap.js:932:8)\n at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:706:12)”,“config”:{“url”:“https://balena.io/etcher/static/config.json",“method”:“get”,“headers”:{“Accept”:"application/json, text/plain, /”,“User-Agent”:“axios/1.7.0”},“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“responseType”:“json”,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false}},“code”:“CERT_HAS_EXPIRED”}
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
log @ electron/js2c/renderer_init.js:13
gui.js:51687 [Axios v1.7.0] Transitional option ‘clarifyTimeoutError’ has been deprecated since v1.0.0 and will be removed in the near future
console. @ gui.js:51687
gui.js:51687 [Axios v1.7.0] Transitional option ‘forcedJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:51687 [Axios v1.7.0] Transitional option ‘silentJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
