Flashing Linux Mint onto a Logitech 32GB USB from Windows 8.1
Flash fails each time, here’s the log
I’m not the most tech savvy, still learning
Taking the iso boot file from the mint website directly
Only including the error parts at the beginning due to url limit rule on new users, if more is needed let me know and I’ll post them in the comments.
Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
log @ electron/js2c/renderer_init.js:13
gui.js:91067 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.7.0, Type = nsis
gui.js:58995 Fri Dec 10 2021 19:01:32 GMT-0600 (Central Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.7.0”,“sample”:0.1,“applicationSessionUuid”:“1bafa41e-7d62-44ca-bb70-76cd486d7892”,“flashingWorkflowUuid”:“be4a0b89-e928-41e4-a89e-1fc2c0e45cc2”})
gui.js:51697 [Axios v1.7.0] Transitional option ‘clarifyTimeoutError’ has been deprecated since v1.0.0 and will be removed in the near future
console. @ gui.js:51697
gui.js:51697 [Axios v1.7.0] Transitional option ‘forcedJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:51697 [Axios v1.7.0] Transitional option ‘silentJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:51697 {“message”:“certificate has expired”,“stack”:“Error: certificate has expired\n at TLSSocket.onConnectSecure (_tls_wrap.js:1497:34)\n at TLSSocket.emit (events.js:315:20)\n at TLSSocket._finishInit (_tls_wrap.js:932:8)\n at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:706:12)”,“config”:{“url”:“https://balena.io/etcher/static/config.json",“method”:“get”,“headers”:{“Accept”:"application/json, text/plain, /”,“User-Agent”:“axios/1.7.0”},“transformRequest”:[null],“transformResponse”:[null],“timeout”:0,“responseType”:“json”,“xsrfCookieName”:“XSRF-TOKEN”,“xsrfHeaderName”:“X-XSRF-TOKEN”,“maxContentLength”:-1,“maxBodyLength”:-1,“transitional”:{“silentJSONParsing”:true,“forcedJSONParsing”:true,“clarifyTimeoutError”:false}},“code”:“CERT_HAS_EXPIRED”}
gui.js:51697 Fri Dec 10 2021 19:01:35 GMT-0600 (Central Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“1bafa41e-7d62-44ca-bb70-76cd486d7892”,“flashingWorkflowUuid”:“be4a0b89-e928-41e4-a89e-1fc2c0e45cc2”})
gui.js:51697 {“stack”:“Error: Command failed: C:\WINDOWS\System32\Wbem\wmic path Win32_LogicalDisk Where DriveType=“4” get DeviceID,ProviderName > “C:\Users\Gypsee\AppData\Local\Temp\etcher\tmp26b0aa272b35.tmp”\nERROR:\r\r\nDescription = Not found\r\r\n\n at ChildProcess.exithandler (child_process.js:317:12)\n at ChildProcess.emit (events.js:315:20)\n at maybeClose (internal/child_process.js:1048:16)\n at Socket. (internal/child_process.js:439:11)\n at Socket.emit (events.js:315:20)\n at Pipe. (net.js:673:12)”,“message”:“Command failed: C:\WINDOWS\System32\Wbem\wmic path Win32_LogicalDisk Where DriveType=“4” get DeviceID,ProviderName > “C:\Users\Gypsee\AppData\Local\Temp\etcher\tmp26b0aa272b35.tmp”\nERROR:\r\r\nDescription = Not found\r\r\n”,“killed”:false,“code”:2147749890,“signal”:null,“cmd”:“tmp26b0aa272b35.tmp”",“stdout”:"",“stderr”:“ERROR:\r\r\nDescription = Not found\r\r\n”}
