Trying to get node-red running on beaglebone black and I was successful until I tried installing the node-red-node-beaglebone nodes.
[Build] make: Leaving directory '/usr/local/lib/node_modules/node-red-admin/node_modules/bcrypt/build'
[Build] added 648 packages in 222.048s
[Build] npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache ver
ify' instead.
[Build] npm ERR!
[Build] npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
[Build]
[Build] npm ERR! A complete log of this run can be found in:
[Build] npm ERR! /root/.npm/_logs/2017-07-11T18_18_22_909Z-debug.log
[Build] Removing intermediate container d5341b034425
[Error] Build failed: The command '/bin/sh -c JOBS=MAX npm install -g node-red node-red-contrib-resinio node-red-admin node-red-node-serialport && npm cache clean && rm -rf /tmp/*' returned a non-zero code: 1
[Info] Uploading successful layers to registry for caching purposes
[=================================> ] 66%
[Info] Successfully updated cache.
To gh_kanr@git.resin.io:gh_kanr/bg08.git
! [remote rejected] master -> master (hook declined)
error: failed to push some refs to 'gh_kanr@git.resin.io:gh_kanr/bg08.git'
Can anyone point me in the right direction I am still new to nodejs and resin. Thanks! please let me know if there is any more information I can provide to help clear this roadblock.
