hello
I have installed balena node-red, except some node does not work for example: with node-red-node-pi-gpio i have this error:
nrgpio python command not running
have you an idea ?
thanks
hello
have you an idea ?
thanks
Hi there, are you running the latest commit from master? just to be clear, are you referring to this project? https://github.com/balenalabs/balena-node-red
where can I see the version in the balena console?
from the balena dashboard, you can check for the CURRENT RELEASE hash
also, can you please confirm you are pushing from this repository? https://github.com/balenalabs/balena-node-red
realease ba89ee2
where is realease in github??
Hi, can you also paste the output of git remote -v ?
my version is 2.1.0
Can you also paste the output of git remote -v and git log --oneline when you run this command in the balena-node-red git repository?
Hello
how i can test This command i am not yet well acquainted with balena console
and for information, I updated balena node-red to 2.2.1
So I switched to node red version 1.1.3
but i still have the same error code
i have this error with node ine the manage palette:
node-red-contrib-balena
1.0.1
Error: /usr/local/lib/node_modules/node-red-contrib-balena/depDevices/depDevices.html does not
exist
Error: /usr/local/lib/node_modules/node-red-contrib-balena/depApps/depApps.html does not exist
Can you open terminal in your system(not balena console) and navigate to the code folder of balena-node-red, then run git remote -v, git log --online.
I’m sorry but I don’t understand
when you say run: git remote -v, git log --online.
where ??
windows terminal?
Hey there! Those commands should be executed on the terminal emulator you were using to push the project to balena.
the terminal to push the project is CMD windows
the command :
Blockquote
doesn t works
git is not a command dos !!
Notice that “git remote -v, git log --online” are two different commands, separated by a comma.
Are you sure this is the command prompt you used to push the code to balena? The error says that it can’t find the git program, which you must have used before in order to clone the project.
i push balena projet with balena cli
i don’t understand
have you a screen shot?
Hi there,
How did you get the code from the github repository? Did you download a folder and unpack or use git? Most of the time people would install the git cli and use the git clone command to clone the repository onto their computer
Our team is actually trying to confirm that you are using this code from this repo: https://github.com/balenalabs/balena-node-red
no i don’t use git, i downloaded the zip package.
and push with balena cli
version 2.1.1
Hello there, did you download your project from here: https://github.com/balenalabs/balena-node-red ?
yes!
