No sound on RPI3B+
Hello, I recently setup a balena sound with my raspberry b3+, but i don’t have sound !
So i try to stop some service, but nothing ! HELP
31.10.20 16:41:40 (+0100) multiroom-server 2020-10-31 15-41-40 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: e3934927f3bc, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:41:40 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Info] (onMessageReceived) Codec: flac
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:41:40 (+0100) multiroom-client ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
31.10.20 16:41:40 (+0100) multiroom-client 2020-10-31 15-41-40 [Error] (onException) Controller::onException
31.10.20 16:41:41 (+0100) audio Setting audio routing rules. Note that this can be changed after startup.
31.10.20 16:41:41 (+0100) audio Routing ‘balena-sound.input’ to ‘snapcast’.
31.10.20 16:41:41 (+0100) audio Routing ‘balena-sound.output’ to ‘0’.
31.10.20 16:41:41 (+0100) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
31.10.20 16:41:42 (+0100) multiroom-client 2020-10-31 15-41-42 [Warn] (sendRequest) timeout while waiting for response to: 2, timeout 2000
31.10.20 16:41:42 (+0100) multiroom-client 2020-10-31 15-41-42 [Error] (worker) Exception in Controller::worker(): Can’t open default PCM device: Connection refused
31.10.20 16:41:42 (+0100) multiroom-server 2020-10-31 15-41-42 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:41:42 (+0100) multiroom-server 2020-10-31 15-41-42 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:41:43 (+0100) audio E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
31.10.20 16:41:43 (+0100) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: “device_id=“0” name=“0” card_name=“alsa_card.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
31.10.20 16:41:43 (+0100) multiroom-server 2020-10-31 15-41-43 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:41:43 (+0100) multiroom-server 2020-10-31 15-41-43 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: e3934927f3bc, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:41:43 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 66.67 ms, adjusting to 23.22 ms
31.10.20 16:41:43 (+0100) multiroom-server 2020-10-31 15-41-43 [Info] (onStateChanged) onStateChanged (balenaSound): 2
31.10.20 16:41:43 (+0100) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:41:43 (+0100) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:41:43 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (onMessageReceived) Codec: flac
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (Alsa) frames: 1323
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (Alsa) Resizing buffer from 0 to 21168
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (Stream) no chunks available
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (Alsa) Failed to get chunk
31.10.20 16:41:43 (+0100) multiroom-client 2020-10-31 15-41-43 [Info] (worker) diff to server [ms]: 0.042
31.10.20 16:41:43 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:41:48 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:41:49 (+0100) sound-supervisor Connected to PulseAudio at 192.168.0.31:4317
31.10.20 16:41:49 (+0100) sound-supervisor Server protocol version: 33
31.10.20 16:41:49 (+0100) sound-supervisor Client protocol version: 33
31.10.20 16:41:49 (+0100) sound-supervisor Playback started, announcing 192.168.0.31 as multi-room master!
31.10.20 16:41:53 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:41:53 (+0100) airplay Shairport-sync started. Device is discoverable as balenaSound AirPlay f01d
31.10.20 16:41:53 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 205.00 ms
31.10.20 16:41:54 (+0100) sound-supervisor Joining the fleet, requesting master info with fleet-sync…
31.10.20 16:42:32 (+0100) audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
31.10.20 16:42:32 (+0100) bluetooth AuthorizeService (/org/bluez/hci0/dev_1C_CC_D6_D1_B4_E7, 00001108-0000-1000-8000-00805f9b34fb)
31.10.20 16:42:33 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 210.00 ms
31.10.20 16:42:35 (+0100) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
31.10.20 16:42:35 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
31.10.20 16:43:03 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 215.00 ms
31.10.20 16:43:17 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 68.54 ms
31.10.20 16:43:43 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 220.00 ms
31.10.20 16:44:03 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 225.00 ms
31.10.20 16:44:23 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 230.00 ms
31.10.20 16:44:43 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 235.00 ms
31.10.20 16:45:03 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 240.00 ms
31.10.20 16:45:33 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 245.00 ms
31.10.20 16:46:02 (+0100) Killing service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:02 (+0100) Killing service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:02 (+0100) Killing service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:02 (+0100) Killing service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:02 (+0100) Killing service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:02 (+0100) Killing service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:03 (+0100) Killing service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:02 (+0100) multiroom-client 2020-10-31 15-46-02 [Error] (Alsa) ERROR. Can’t wait for PCM to become ready: I/O error
31.10.20 16:46:02 (+0100) multiroom-client Assertion failed: pcm && availp && delayp (pcm.c: snd_pcm_avail_delay: 2987)
31.10.20 16:46:02 (+0100) sound-supervisor Malformed packet!
31.10.20 16:46:02 (+0100) audio W: [pulseaudio] module.c: After module unload, module ‘module-null-sink’ was still loaded!
31.10.20 16:46:02 (+0100) multiroom-server 2020-10-31 15-46-02 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:46:02 (+0100) multiroom-server 2020-10-31 15-46-02 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:46:03 (+0100) Killing service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:03 (+0100) multiroom-server 2020-10-31 15-46-03 [Info] (onStateChanged) onStateChanged (balenaSound): 1
31.10.20 16:46:04 (+0100) Service exited ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:05 (+0100) Killed service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:05 (+0100) Service exited ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:05 (+0100) Service exited ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:05 (+0100) Killed service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:05 (+0100) Service exited ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:05 (+0100) Killed service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:05 (+0100) Killed service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:07 (+0100) Installing service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:07 (+0100) Installing service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:07 (+0100) Installing service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:07 (+0100) Installing service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:07 (+0100) Installed service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:07 (+0100) Starting service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:07 (+0100) Installed service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:07 (+0100) Starting service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:08 (+0100) Installed service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:08 (+0100) Starting service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:08 (+0100) Installed service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:08 (+0100) Starting service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:10 (+0100) Started service ‘sound-supervisor sha256:d987e5fad1f4544573e527a04b649f987641207efc13bb4e8b923112f58e6c05’
31.10.20 16:46:11 (+0100) Started service ‘upnp sha256:0367fee97ae831544aeddc89b67fc4de6ad3d05b089fd16f1cdb97a58a7ce821’
31.10.20 16:46:10 (+0100) upnp Starting UPnP plugin…
31.10.20 16:46:10 (+0100) upnp Device name: balenaSound UPnP f01d
31.10.20 16:46:12 (+0100) Started service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:46:12 (+0100) Started service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:46:12 (+0100) upnp gmediarender 0.0.7-git started [ gmediarender 0.0.7-git (libupnp-1.8.4; glib-2.58.1; gstreamer-1.14.4) ].
31.10.20 16:46:12 (+0100) upnp Logging switched off. Enable with --logfile= (or --logfile=stdout for console)
31.10.20 16:46:12 (+0100) audio
31.10.20 16:46:12 (+0100) audio — Audio —
31.10.20 16:46:12 (+0100) audio Starting audio service with settings:
31.10.20 16:46:12 (+0100) audio - Pulse log level: NOTICE
31.10.20 16:46:12 (+0100) audio - Default output: AUTO
31.10.20 16:46:12 (+0100) audio Detected audio cards:
31.10.20 16:46:13 (+0100) audio 0 vc4hdmi vc4-hdmi-vc4-hdmi
31.10.20 16:46:13 (+0100) upnp Ready for rendering.
31.10.20 16:46:15 (+0100) sound-supervisor
31.10.20 16:46:15 (+0100) sound-supervisor > sound-supervisor@1.0.0 start /usr/src
31.10.20 16:46:15 (+0100) sound-supervisor > node build/index.js
31.10.20 16:46:16 (+0100) Service exited ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:16 (+0100) Service exited ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:16 (+0100) Service exited ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:16 (+0100) Killed service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:16 (+0100) Killed service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:16 (+0100) Killed service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:16 (+0100) Service exited ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:16 (+0100) Killed service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:17 (+0100) multiroom-client Waiting for sound supervisor to start
31.10.20 16:46:18 (+0100) Installing service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:18 (+0100) Installing service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:18 (+0100) sound-supervisor Sound supervisor listening on port 3000
31.10.20 16:46:18 (+0100) sound-supervisor Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.0.31:4317
31.10.20 16:46:18 (+0100) Installing service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:18 (+0100) Installing service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:18 (+0100) Installed service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:18 (+0100) Starting service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:19 (+0100) Installed service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:19 (+0100) Starting service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:19 (+0100) Installed service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:19 (+0100) Starting service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:19 (+0100) Installed service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:19 (+0100) Starting service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:21 (+0100) Started service ‘airplay sha256:62a3e16d069b949086d24528bb883d05e20f01f2ad33d1f1638681fe54b17dfa’
31.10.20 16:46:20 (+0100) airplay Starting AirPlay plugin…
31.10.20 16:46:20 (+0100) airplay Device name: balenaSound AirPlay f01d
31.10.20 16:46:21 (+0100) Started service ‘bluetooth sha256:7380e2ea9a694d75ccec589ed92a5671a530486479ea803cd8479d0178afe572’
31.10.20 16:46:21 (+0100) bluetooth Running balena base image entrypoint…
31.10.20 16:46:21 (+0100) bluetooth — Bluetooth —
31.10.20 16:46:21 (+0100) bluetooth Starting bluetooth service with settings:
31.10.20 16:46:21 (+0100) bluetooth - Device name: balenaOS f01d
31.10.20 16:46:21 (+0100) bluetooth - HCI interface: hci0
31.10.20 16:46:21 (+0100) bluetooth - Pairing mode: SSP
31.10.20 16:46:21 (+0100) bluetooth - PIN code: 0000
31.10.20 16:46:21 (+0100) bluetooth Available HCI interfaces: hci0
31.10.20 16:46:21 (+0100) bluetooth Resetting hci0
31.10.20 16:46:21 (+0100) bluetooth Configuring selected interface: hci0
31.10.20 16:46:21 (+0100) bluetooth hci0 Set Connectable complete, settings: powered connectable ssp br/edr le secure-conn
31.10.20 16:46:21 (+0100) bluetooth hci0 Set Bondable complete, settings: powered connectable bondable ssp br/edr le secure-conn
31.10.20 16:46:21 (+0100) bluetooth hci0 Set Discoverable complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
31.10.20 16:46:21 (+0100) bluetooth hci0 Set Secure Simple Pairing complete, settings: powered connectable discoverable bondable ssp br/edr le secure-conn
31.10.20 16:46:21 (+0100) bluetooth Pairing mode set to ‘Secure Simple Pairing Mode (SSPM)’. PIN code is NOT required.
31.10.20 16:46:22 (+0100) multiroom-client Waiting for sound supervisor to start
31.10.20 16:46:22 (+0100) multiroom-client Starting multi-room client…
31.10.20 16:46:22 (+0100) multiroom-client Mode: MULTI_ROOM
31.10.20 16:46:22 (+0100) multiroom-client Target snapcast server: 192.168.0.31
31.10.20 16:46:22 (+0100) Started service ‘spotify sha256:feec84819207ed1d79c50883a16b6ddad4b04c09d3a8c82979ff056069ac2feb’
31.10.20 16:46:22 (+0100) spotify Starting Spotify plugin…
31.10.20 16:46:22 (+0100) spotify Device name: balenaSound Spotify f01d
31.10.20 16:46:22 (+0100) spotify Volume normalization enabled.
31.10.20 16:46:22 (+0100) spotify [2020-10-31T15:46:22Z INFO librespot] librespot (raspotify v0.14.0) 6aac8a6 (2020-07-24). Built on 2020-07-26. Build ID: wPNyqn0m
31.10.20 16:46:22 (+0100) multiroom-client 2020-10-31 15-46-22 [Info] (main) Latency: 0
31.10.20 16:46:22 (+0100) multiroom-client 2020-10-31 15-46-22 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:46:22 (+0100) multiroom-client 2020-10-31 15-46-22 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:46:23 (+0100) sound-supervisor Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.0.31:4317
31.10.20 16:46:23 (+0100) bluetooth Bluetooth agent started!
31.10.20 16:46:23 (+0100) multiroom-client 2020-10-31 15-46-23 [Error] (onException) Controller::onException
31.10.20 16:46:23 (+0100) Started service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:46:23 (+0100) multiroom-server Starting multi-room server…
31.10.20 16:46:23 (+0100) multiroom-server Mode: MULTI_ROOM
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (main) Adding stream: pipe:///var/cache/snapcast/snapfifo?name=balenaSound
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Notice] (init) Settings file: “/var/cache/snapcast/server.json”
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Error] (Avahi) Failed to create client: Daemon not running
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (start) Creating TCP acceptor for address: 0.0.0.0, port: 1705
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (start) Creating HTTP acceptor for address: 0.0.0.0, port: 1780
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (PcmStream) PcmStream sampleFormat: 44100:16:2
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (PcmStream) metadata={
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (PcmStream) “STREAM”: “balenaSound”
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (PcmStream) }
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (onMetaChanged) onMetaChanged (balenaSound)
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (PipeStream) PipeStream mode: create
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (start) Stream: {“fragment”:”",“host”:"",“path”:"/var/cache/snapcast/snapfifo",“query”:{“chunk_ms”:“20”,“codec”:“flac”,“name”:“balenaSound”,“sampleformat”:“44100:16:2”},“raw”:“pipe:////var/cache/snapcast/snapfifo?chunk_ms=20&codec=flac&name=balenaSound&sampleformat=44100:16:2”,“scheme”:“pipe”}
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Error] (PosixStream) Exception: end of file
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (start) Creating stream acceptor for address: 0.0.0.0, port: 1704
31.10.20 16:46:23 (+0100) multiroom-server 2020-10-31 15-46-23 [Info] (main) number of threads: 4, hw threads: 4
31.10.20 16:46:23 (+0100) audio Setting audio routing rules. Note that this can be changed after startup.
31.10.20 16:46:23 (+0100) audio Routing ‘balena-sound.input’ to ‘snapcast’.
31.10.20 16:46:23 (+0100) audio Routing ‘balena-sound.output’ to ‘0’.
31.10.20 16:46:23 (+0100) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
31.10.20 16:46:24 (+0100) multiroom-client 2020-10-31 15-46-24 [Warn] (sendRequest) timeout while waiting for response to: 2, timeout 2000
31.10.20 16:46:24 (+0100) multiroom-client 2020-10-31 15-46-24 [Error] (worker) Exception in Controller::worker(): read_some: Connection reset by peer
31.10.20 16:46:24 (+0100) multiroom-client 2020-10-31 15-46-24 [Error] (stop) Error in socket shutdown: Socket not connected
31.10.20 16:46:24 (+0100) audio E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
31.10.20 16:46:24 (+0100) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: "device_id=“0” name=“0” card_name=“alsa_card.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
31.10.20 16:46:24 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 66.67 ms, adjusting to 23.22 ms
31.10.20 16:46:24 (+0100) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:46:24 (+0100) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:46:24 (+0100) multiroom-server 2020-10-31 15-46-24 [Info] (onStateChanged) onStateChanged (balenaSound): 2
31.10.20 16:46:25 (+0100) multiroom-server 2020-10-31 15-46-25 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:46:25 (+0100) multiroom-server 2020-10-31 15-46-25 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: 6cc96880bc92, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:46:25 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (onMessageReceived) Codec: flac
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (Alsa) frames: 1323
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Warn] (Alsa) snd_pcm_avail_delay failed: I/O error, avail: 0, delay: 0, retrying.
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (Alsa) Resizing buffer from 0 to 21168
31.10.20 16:46:25 (+0100) multiroom-client 2020-10-31 15-46-25 [Info] (worker) diff to server [ms]: 0.026
31.10.20 16:46:26 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:46:31 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:46:33 (+0100) sound-supervisor Connected to PulseAudio at 192.168.0.31:4317
31.10.20 16:46:33 (+0100) sound-supervisor Server protocol version: 33
31.10.20 16:46:33 (+0100) sound-supervisor Client protocol version: 33
31.10.20 16:46:33 (+0100) sound-supervisor Playback started, announcing 192.168.0.31 as multi-room master!
31.10.20 16:46:36 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:46:36 (+0100) airplay Shairport-sync started. Device is discoverable as balenaSound AirPlay f01d
31.10.20 16:46:38 (+0100) sound-supervisor Joining the fleet, requesting master info with fleet-sync…
31.10.20 16:46:52 (+0100) audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
31.10.20 16:46:55 (+0100) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
31.10.20 16:46:55 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
31.10.20 16:47:04 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 205.00 ms
31.10.20 16:47:29 (+0100) Killing service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:47:29 (+0100) multiroom-client 2020-10-31 15-47-29 [Error] (Alsa) ERROR. Can’t wait for PCM to become ready: I/O error
31.10.20 16:47:29 (+0100) multiroom-server 2020-10-31 15-47-29 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:47:29 (+0100) multiroom-server 2020-10-31 15-47-29 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:47:29 (+0100) audio W: [pulseaudio] module.c: After module unload, module ‘module-null-sink’ was still loaded!
31.10.20 16:47:29 (+0100) multiroom-client Assertion failed: pcm && availp && delayp (pcm.c: snd_pcm_avail_delay: 2987)
31.10.20 16:47:29 (+0100) sound-supervisor Malformed packet!
31.10.20 16:47:30 (+0100) multiroom-server 2020-10-31 15-47-30 [Info] (onStateChanged) onStateChanged (balenaSound): 1
31.10.20 16:47:30 (+0100) Service exited ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:47:30 (+0100) Killed service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:47:30 (+0100) Service exited ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:47:35 (+0100) Killing service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:47:35 (+0100) Service is already stopped, removing container ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:47:35 (+0100) Killed service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:47:36 (+0100) Killing service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:47:48 (+0100) Killed service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:47:48 (+0100) Service exited ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:48:40 (+0100) Starting service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:48:42 (+0100) Started service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:48:42 (+0100) Restarting service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:48:42 (+0100) audio
31.10.20 16:48:42 (+0100) audio — Audio —
31.10.20 16:48:42 (+0100) audio Starting audio service with settings:
31.10.20 16:48:42 (+0100) audio - Pulse log level: NOTICE
31.10.20 16:48:42 (+0100) audio - Default output: AUTO
31.10.20 16:48:42 (+0100) audio Detected audio cards:
31.10.20 16:48:42 (+0100) audio 0 vc4hdmi vc4-hdmi-vc4-hdmi
31.10.20 16:48:53 (+0100) audio Setting audio routing rules. Note that this can be changed after startup.
31.10.20 16:48:53 (+0100) audio Routing ‘balena-sound.input’ to ‘snapcast’.
31.10.20 16:48:53 (+0100) audio Routing ‘balena-sound.output’ to ‘0’.
31.10.20 16:48:53 (+0100) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
31.10.20 16:48:53 (+0100) audio E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
31.10.20 16:48:53 (+0100) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: "device_id=“0” name=“0” card_name=“alsa_card.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
31.10.20 16:48:53 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 66.67 ms, adjusting to 23.22 ms
31.10.20 16:48:53 (+0100) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:48:53 (+0100) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:49:10 (+0100) audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
31.10.20 16:49:13 (+0100) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
31.10.20 16:49:13 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
I used bluetooth. And sorry if my english is bad I am french.
I retried after a restart ;
31.10.20 16:59:16 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:59:17 (+0100) Started service ‘multiroom-client sha256:97c03309737ea95d8e8f656f13cc840a3cdec3ca7f5a8ace9079c9d3cb173021’
31.10.20 16:59:16 (+0100) sound-supervisor Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.0.31:4317
31.10.20 16:59:17 (+0100) multiroom-client Starting multi-room client…
31.10.20 16:59:17 (+0100) multiroom-client Mode: MULTI_ROOM
31.10.20 16:59:17 (+0100) multiroom-client Target snapcast server: 192.168.0.31
31.10.20 16:59:17 (+0100) multiroom-client 2020-10-31 15-59-17 [Info] (main) Latency: 0
31.10.20 16:59:17 (+0100) multiroom-client 2020-10-31 15-59-17 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:59:17 (+0100) multiroom-client 2020-10-31 15-59-17 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:59:17 (+0100) Started service ‘audio sha256:ef501b350f2cfd654eab6dd9091a6fe4cab95e02d5c2b6362ba70e4d3fa846f5’
31.10.20 16:59:17 (+0100) audio
31.10.20 16:59:17 (+0100) audio — Audio —
31.10.20 16:59:17 (+0100) audio Starting audio service with settings:
31.10.20 16:59:17 (+0100) audio - Pulse log level: NOTICE
31.10.20 16:59:17 (+0100) audio - Default output: AUTO
31.10.20 16:59:17 (+0100) audio Detected audio cards:
31.10.20 16:59:18 (+0100) audio 0 vc4hdmi vc4-hdmi-vc4-hdmi
31.10.20 16:59:18 (+0100) multiroom-client 2020-10-31 15-59-18 [Error] (onException) Controller::onException
31.10.20 16:59:18 (+0100) Started service ‘multiroom-server sha256:8d1867f63c5c279174eac1b443d9a35fb19cf481e4750ca87232e36d52e7fab6’
31.10.20 16:59:18 (+0100) multiroom-server Starting multi-room server…
31.10.20 16:59:18 (+0100) multiroom-server Mode: MULTI_ROOM
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (main) Adding stream: pipe:///var/cache/snapcast/snapfifo?name=balenaSound
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Notice] (init) Settings file: “/var/cache/snapcast/server.json”
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Error] (Avahi) Failed to create client: Daemon not running
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (start) Creating TCP acceptor for address: 0.0.0.0, port: 1705
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (start) Creating HTTP acceptor for address: 0.0.0.0, port: 1780
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (PcmStream) PcmStream sampleFormat: 44100:16:2
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (PcmStream) metadata={
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (PcmStream) “STREAM”: “balenaSound”
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (PcmStream) }
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (onMetaChanged) onMetaChanged (balenaSound)
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (PipeStream) PipeStream mode: create
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (start) Stream: {“fragment”:"",“host”:"",“path”:"/var/cache/snapcast/snapfifo",“query”:{“chunk_ms”:“20”,“codec”:“flac”,“name”:“balenaSound”,“sampleformat”:“44100:16:2”},“raw”:“pipe:////var/cache/snapcast/snapfifo?chunk_ms=20&codec=flac&name=balenaSound&sampleformat=44100:16:2”,“scheme”:“pipe”}
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Error] (PosixStream) Exception: end of file
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (start) Creating stream acceptor for address: 0.0.0.0, port: 1704
31.10.20 16:59:18 (+0100) multiroom-server 2020-10-31 15-59-18 [Info] (main) number of threads: 4, hw threads: 4
31.10.20 16:59:19 (+0100) multiroom-client 2020-10-31 15-59-19 [Warn] (sendRequest) timeout while waiting for response to: 2, timeout 2000
31.10.20 16:59:19 (+0100) multiroom-client 2020-10-31 15-59-19 [Error] (worker) Exception in Controller::worker(): read_some: Connection reset by peer
31.10.20 16:59:19 (+0100) multiroom-client 2020-10-31 15-59-19 [Error] (stop) Error in socket shutdown: Socket not connected
31.10.20 16:59:20 (+0100) multiroom-server 2020-10-31 15-59-20 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:59:20 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Info] (onMessageReceived) Codec: flac
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:59:20 (+0100) multiroom-client ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
31.10.20 16:59:20 (+0100) multiroom-server 2020-10-31 15-59-20 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: 347e0168c1f6, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:59:20 (+0100) multiroom-client 2020-10-31 15-59-20 [Error] (onException) Controller::onException
31.10.20 16:59:21 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:59:22 (+0100) multiroom-client 2020-10-31 15-59-22 [Warn] (sendRequest) timeout while waiting for response to: 3, timeout 2000
31.10.20 16:59:22 (+0100) multiroom-client 2020-10-31 15-59-22 [Error] (worker) Exception in Controller::worker(): Can’t open default PCM device: Connection refused
31.10.20 16:59:22 (+0100) multiroom-server 2020-10-31 15-59-22 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:59:22 (+0100) multiroom-server 2020-10-31 15-59-22 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:59:23 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Info] (onMessageReceived) Codec: flac
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:59:23 (+0100) multiroom-client ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
31.10.20 16:59:23 (+0100) multiroom-client 2020-10-31 15-59-23 [Error] (onException) Controller::onException
31.10.20 16:59:23 (+0100) multiroom-server 2020-10-31 15-59-23 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:59:23 (+0100) multiroom-server 2020-10-31 15-59-23 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: 347e0168c1f6, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:59:25 (+0100) multiroom-server 2020-10-31 15-59-25 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:59:25 (+0100) multiroom-server 2020-10-31 15-59-25 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:59:25 (+0100) multiroom-client 2020-10-31 15-59-25 [Warn] (sendRequest) timeout while waiting for response to: 4, timeout 2000
31.10.20 16:59:25 (+0100) multiroom-client 2020-10-31 15-59-25 [Error] (worker) Exception in Controller::worker(): Can’t open default PCM device: Connection refused
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:59:26 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Info] (onMessageReceived) Codec: flac
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:59:26 (+0100) multiroom-client ALSA lib pulse.c:242:(pulse_connect) PulseAudio: Unable to connect: Connection refused
31.10.20 16:59:26 (+0100) multiroom-client 2020-10-31 15-59-26 [Error] (onException) Controller::onException
31.10.20 16:59:26 (+0100) multiroom-server 2020-10-31 15-59-26 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:59:26 (+0100) multiroom-server 2020-10-31 15-59-26 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: 347e0168c1f6, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:59:26 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:59:28 (+0100) multiroom-server 2020-10-31 15-59-28 [Error] (StreamSession) Error reading message header of length 0: End of file
31.10.20 16:59:28 (+0100) multiroom-server 2020-10-31 15-59-28 [Info] (onDisconnect) onDisconnect: 02:42:ac:11:00:04
31.10.20 16:59:28 (+0100) audio Setting audio routing rules. Note that this can be changed after startup.
31.10.20 16:59:28 (+0100) audio Routing ‘balena-sound.input’ to ‘snapcast’.
31.10.20 16:59:28 (+0100) audio Routing ‘balena-sound.output’ to ‘0’.
31.10.20 16:59:28 (+0100) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
31.10.20 16:59:28 (+0100) multiroom-client 2020-10-31 15-59-28 [Warn] (sendRequest) timeout while waiting for response to: 5, timeout 2000
31.10.20 16:59:28 (+0100) multiroom-client 2020-10-31 15-59-28 [Error] (worker) Exception in Controller::worker(): Can’t open default PCM device: Connection refused
31.10.20 16:59:28 (+0100) audio E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
31.10.20 16:59:28 (+0100) audio E: [pulseaudio] module.c: Failed to load module “module-alsa-card” (argument: "device_id=“0” name=“0” card_name=“alsa_card.0” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=yes card_properties=“module-udev-detect.discovered=1"”): initialization failed.
31.10.20 16:59:28 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 66.67 ms, adjusting to 23.22 ms
31.10.20 16:59:28 (+0100) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:59:28 (+0100) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Notice] (start) Connected to 192.168.0.31
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (getMacAddress) My MAC: “02:42:ac:11:00:04”, socket: 5
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (onMessageReceived) ServerSettings - buffer: 1000, latency: 0, volume: 100, muted: 0
31.10.20 16:59:29 (+0100) multiroom-client metadata:{“STREAM”:“balenaSound”}
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (onMessageReceived) Codec: flac
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Notice] (state) sampleformat: 44100:16:2
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (Alsa) frames: 1323
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (Alsa) Resizing buffer from 0 to 21168
31.10.20 16:59:29 (+0100) multiroom-client 2020-10-31 15-59-29 [Info] (worker) diff to server [ms]: 0.029
31.10.20 16:59:29 (+0100) multiroom-server 2020-10-31 15-59-29 [Notice] (handleAccept) StreamServer::NewConnection: 172.17.0.1
31.10.20 16:59:29 (+0100) multiroom-server 2020-10-31 15-59-29 [Info] (onMessageReceived) Hello from 02:42:ac:11:00:04, host: 347e0168c1f6, v0.19.0, ClientName: Snapclient, OS: Alpine Linux v3.12, Arch: aarch64, Protocol version: 2
31.10.20 16:59:29 (+0100) multiroom-server 2020-10-31 15-59-29 [Info] (onStateChanged) onStateChanged (balenaSound): 2
31.10.20 16:59:31 (+0100) sound-supervisor Connected to PulseAudio at 192.168.0.31:4317
31.10.20 16:59:31 (+0100) sound-supervisor Server protocol version: 33
31.10.20 16:59:31 (+0100) sound-supervisor Client protocol version: 33
31.10.20 16:59:31 (+0100) sound-supervisor Playback started, announcing 192.168.0.31 as multi-room master!
31.10.20 16:59:31 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:59:36 (+0100) airplay Waiting for audioblock to start…
31.10.20 16:59:36 (+0100) airplay Shairport-sync started. Device is discoverable as balenaSound AirPlay f01d
31.10.20 16:59:36 (+0100) sound-supervisor Joining the fleet, requesting master info with fleet-sync…
31.10.20 17:00:09 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 205.00 ms
31.10.20 17:00:19 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 210.00 ms
31.10.20 17:00:38 (+0100) audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
31.10.20 17:00:39 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 215.00 ms
31.10.20 17:00:41 (+0100) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
31.10.20 17:00:41 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
31.10.20 17:00:49 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 220.00 ms
31.10.20 17:01:19 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 225.00 ms
31.10.20 17:01:20 (+0100) audio E: [pulseaudio] backend-native.c: socket(SEQPACKET, SCO) Address family not supported by protocol
31.10.20 17:01:23 (+0100) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
31.10.20 17:01:23 (+0100) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
31.10.20 17:01:49 (+0100) audio W: [pulseaudio] module-loopback.c: Too many underruns, increasing latency to 230.00 ms
@Haruku STP de temps en temps fait ton post en français , il y aura toujours QQu’un qui te répondra sur ton sujet :wink:
Hi, could you please double check you are using a 32bits application and installed a 32bits BalenaOS? Also, what is the version of BalenaOS it is running?
Hi, i use a 64 bit version of Balena OS [balenaOS 2.47.0+rev1]
Could you try with the 32bit OS and App. I think there is a dependency on the 32-bit OS so it would be good to see that working before trying to debug on 64-bit.
I try it but my raspberry wont show up on the dashboard, i will retry in one hour
Hi Evann,
Did you manage to get your device to show up on the dashboard? Let us know if there is anything we can help you with
I had the same problem but if you reinstall using the balenaSound website, it should work fine.
I think there’s actually an issue open for this (No sound output with balenaOS 64 bit on Raspberry Pi 3 · Issue #82 · balenalabs/balena-sound · GitHub) . There’s a comment there that solved the issue for me - remove the vc4-kms-v3d overlay from the device configuration and reboot. That way you won’t need to install the 32 bit OS (actually I couldn’t find the 32 bit option when trying to add a device in Balena Cloud).
