I’ve started getting a lot of musb errors I didn’t see in the past. I running balenaOS 2.67.3+rev1.
[ 266.963086] ------------[ cut here ]------------
[ 266.967954] WARNING: CPU: 0 PID: 802 at drivers/usb/musb/musb_host.c:113 musb_h_tx_flush_fifo+0x150/0x154
[ 266.977913] musb-hdrc musb-hdrc.1: Could not flush host TX10 fifo: csr: 2003
[ 266.985250] Modules linked in: wpanusb(O) hm3301(O) ip6t_REJECT nf_reject_ipv6 ip6table_filter xt_state ipt_REJECT nf_reject_ipv4 sgp30 crc8 bme680_i2c bme680_core nhc_udp nhc_routing nhc_dest nhc_mobility nhc_ipv6 nhc_hop ieee802154_6lowpan nhc_fragment 6lowpan atusb mac802154 ieee802154 ccm xt_MASQUERADE nf_conntrack_netlink nfnetlink xfrm_user xfrm_algo br_netfilter xt_owner cmac algif_hash aes_arm_bs crypto_simd cryptd algif_skcipher af_alg bnep wl18xx wlcore mac80211 cfg80211 libarc4 hci_uart rfcomm bluetooth ecdh_generic ecc icss_iep prueth_ecap smsc95xx usbnet cdc_acm mii wlcore_sdio evdev sch_fq_codel [last unloaded: wpanusb]
[ 267.043820] CPU: 0 PID: 802 Comm: ModemManager Tainted: G O 5.4.70+ #1
[ 267.051969] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 267.058310] Backtrace:
[ 267.060870] [<c010f248>] (dump_backtrace) from [<c010f5f8>] (show_stack+0x20/0x24)
[ 267.068754] r7:60030193 r6:c1add0e8 r5:00000000 r4:c1add0e8
[ 267.074655] [<c010f5d8>] (show_stack) from [<c0dd2684>] (dump_stack+0xb8/0xcc)
[ 267.082182] [<c0dd25cc>] (dump_stack) from [<c013d50c>] (__warn+0xe0/0x108)
[ 267.089433] r7:00000071 r6:c0a00b70 r5:00000009 r4:c10b6e84
[ 267.095330] [<c013d42c>] (__warn) from [<c013d910>] (warn_slowpath_fmt+0xa8/0xcc)
[ 267.103122] r7:c0a00b70 r6:00000071 r5:c10b6e84 r4:c10b6edc
[ 267.109016] [<c013d86c>] (warn_slowpath_fmt) from [<c0a00b70>] (musb_h_tx_flush_fifo+0x150/0x154)
[ 267.118254] r8:c1b60628 r7:c1b60630 r6:e0051c10 r5:db1b6040 r4:00002003
[ 267.125234] [<c0a00a20>] (musb_h_tx_flush_fifo) from [<c0a01b28>] (musb_cleanup_urb+0x88/0xf0)
[ 267.134199] r10:00000628 r9:d9b49180 r8:c1b60630 r7:e0051c10 r6:00000000 r5:daf73000
[ 267.142351] r4:db1b6bfc
[ 267.144990] [<c0a01aa0>] (musb_cleanup_urb) from [<c0a02584>] (musb_urb_dequeue+0x1b4/0x1f4)
[ 267.153778] r10:00000001 r9:d9b49180 r8:db1b6040 r7:c0010400 r6:a0030113 r5:00000000
[ 267.161927] r4:daf73000 r3:d9b49180
[ 267.165653] [<c0a023d0>] (musb_urb_dequeue) from [<c098953c>] (unlink1+0x3c/0x11c)
[ 267.173536] r10:00000000 r9:00000008 r8:dc53141c r7:fffffffe r6:fffffffe r5:db72d000
[ 267.181688] r4:daf73000 r3:c0a023d0
[ 267.185410] [<c0989500>] (unlink1) from [<c098b094>] (usb_hcd_unlink_urb+0x80/0xd8)
[ 267.193383] r9:00000008 r8:dc53141c r7:da9da000 r6:fffffffe r5:60030113 r4:daf73000
[ 267.201446] [<c098b014>] (usb_hcd_unlink_urb) from [<c098ca1c>] (usb_kill_urb.part.0+0x54/0xe8)
[ 267.210503] r7:dc531000 r6:daf73010 r5:dc531180 r4:daf73000
[ 267.216395] [<c098c9c8>] (usb_kill_urb.part.0) from [<c098cae8>] (usb_kill_urb+0x38/0x3c)
[ 267.224911] r6:dc531000 r5:dc531180 r4:dc531048
[ 267.229735] [<c098cab0>] (usb_kill_urb) from [<bf01c3a4>] (acm_kill_urbs+0x34/0x6c [cdc_acm])
[ 267.238616] [<bf01c370>] (acm_kill_urbs [cdc_acm]) from [<bf01c6b4>] (acm_port_shutdown+0x88/0x8c [cdc_acm])
[ 267.248851] r7:dc531000 r6:00000000 r5:dc531510 r4:dc531014
[ 267.254760] [<bf01c62c>] (acm_port_shutdown [cdc_acm]) from [<c07a9b88>] (tty_port_shutdown+0xa0/0xa4)
[ 267.264449] r9:00000008 r8:d980ba80 r7:dc5310a8 r6:d2df8600 r5:00000000 r4:dc531014
[ 267.272516] [<c07a9ae8>] (tty_port_shutdown) from [<c07aa400>] (tty_port_close+0x4c/0x84)
[ 267.281028] r7:db000cd0 r6:db32fdb8 r5:d2df8600 r4:dc531014
[ 267.286927] [<c07aa3b4>] (tty_port_close) from [<bf01c24c>] (acm_tty_close+0x28/0x2c [cdc_acm])
[ 267.295983] r5:00000000 r4:d2df8600
[ 267.299709] [<bf01c224>] (acm_tty_close [cdc_acm]) from [<c079f848>] (tty_release+0x100/0x5fc)
[ 267.308734] [<c079f748>] (tty_release) from [<c034bce8>] (__fput+0x98/0x230)
[ 267.316119] r10:d980ba88 r9:00000008 r8:da13b220 r7:db000cd0 r6:db32fdb8 r5:000e0003
[ 267.324316] r4:d980ba80
[ 267.326970] [<c034bc50>] (__fput) from [<c034be98>] (____fput+0x18/0x1c)
[ 267.333991] r10:dab53fb0 r9:dc2e3b98 r8:dc2e3bc4 r7:c1b14b34 r6:dc2e3640 r5:d980ba80
[ 267.342189] r4:00000000
[ 267.344853] [<c034be80>] (____fput) from [<c0160c0c>] (task_work_run+0xa0/0xbc)
[ 267.352512] [<c0160b6c>] (task_work_run) from [<c010df3c>] (do_work_pending+0x4ec/0x5e8)
[ 267.360988] r9:fffffe30 r8:5ac3c35a r7:dab52000 r6:c0101204 r5:dab53f28 r4:ffffe000
[ 267.369102] [<c010da50>] (do_work_pending) from [<c010106c>] (slow_work_pending+0xc/0x20)
[ 267.377665] Exception stack(0xdab53fb0 to 0xdab53ff8)
[ 267.382957] 3fa0: 00000000 00000002 00000000 00000000
[ 267.391524] 3fc0: 00000009 b6f9d4d0 00000000 00000006 00000000 0000ffff 00000000 00000000
[ 267.400090] 3fe0: 00000006 beb11a28 b6983e89 b6985c16 80010030 00000009
[ 267.407021] r10:00000006 r9:dab52000 r8:c0101204 r7:00000006 r6:00000000 r5:b6f9d4d0
[ 267.415219] r4:00000009
[ 267.417868] ---[ end trace 8b0dbfd5ad5f2d34 ]---
