Recently I bought an SD card for my RPi4, and I flashed Raspberry Pi OS to it. This SD card was a replacement for an identical one that was bricked when I bought it. However, I am trying to flash Astroberry to it, and it keeps on having write errors. I am using a Macbook pro mid 2012, macOS 10.15.7
The error in the log looks like this:
gui.js:38454 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:51110 Successfully connected to IPC server: etcher-server-2218, socket root /var/folders/d2/b7qtw5j96mqd8d9ntw275x180000gn/T/
gui.js:51110 Image: /Users/name/Downloads/astroberry-server_2.0.4.img.zip
gui.js:51110 Devices: /dev/disk2
gui.js:51110 Auto blockmapping: true
gui.js:51110 Decompress first: true
gui.js:38454 Flashing 1 device, 0% at 7.70 MB/s (total 7.70 MB/s) eta in 1039s with 0 failed devices
gui.js:38454 Flashing 1 device, 0% at 12.40 MB/s (total 12.40 MB/s) eta in 641s with 0 failed devices
gui.js:38454 Flashing 1 device, 0% at 18.20 MB/s (total 18.20 MB/s) eta in 437s with 0 failed devices
gui.js:38454 Flashing 1 device, 0% at 19.30 MB/s (total 19.30 MB/s) eta in 411s with 0 failed devices
gui.js:38454 Flashing 1 device, 1% at 19.30 MB/s (total 19.30 MB/s) eta in 410s with 0 failed devices
gui.js:38454 Flashing 1 device, 1% at 18.80 MB/s (total 18.80 MB/s) eta in 421s with 0 failed devices
2gui.js:38454 Flashing 1 device, 1% at 18.70 MB/s (total 18.70 MB/s) eta in 421s with 0 failed devices
gui.js:38454 Flashing 1 device, 1% at 19.30 MB/s (total 19.30 MB/s) eta in 407s with 0 failed devices
gui.js:38454 Flashing 1 device, 2% at 18.20 MB/s (total 18.20 MB/s) eta in 430s with 0 failed devices
gui.js:51110 Fri May 27 2022 20:28:37 GMT+1000 (Australian Eastern Standard Time) Input/output error ({"image":{"size":7997792768,"compressedSize":4063080665,"hasMBR":true,"path":"/Users/name/Downloads/astroberry-server_2.0.4.img.zip","partitions":[{"offset":4194304,"size":268435456,"type":12,"index":1},{"offset":272629760,"size":7725163008,"type":131,"index":2}],"isCompressed":true,"name":"astroberry-server_2.0.4.img","extension":"zip"},"drives":[{"size":15479078912,"isVirtual":false,"enumerator":"DiskArbitration","logicalBlockSize":512,"raw":"/dev/rdisk2","error":null,"isReadOnly":false,"displayName":"/dev/disk2","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"/dev/disk2","busVersion":null,"isSystem":false,"busType":"Secure Digital","isCard":true,"isUSB":false,"devicePath":"IODeviceTree:/PCI0@0/RP01@1C/SDXC@0,1","mountpoints":[{"path":"/Volumes/UNTITLED","label":"UNTITLED"}],"description":"Apple SDXC Reader Media","isUAS":null,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"6b947916-bec3-4978-a80d-109be592e1a6","flashInstanceUuid":"6b947916-bec3-4978-a80d-109be592e1a6","sample":0.1,"applicationSessionUuid":"c7deae11-52aa-4d52-8e71-7239c3ffdfc7","flashingWorkflowUuid":"a83186d8-ac97-4b80-a8bc-da6aa8ff2a76"})
I do have a windows desktop (which can be linux if absolutely neccessary), but it does not have an SD card reader, and my windows laptop has a broken SD card driver (windows blocks the driver from working) so I do not have any other devices to write it with.
Is my SD card bricked, or should I go out and buy another SD card reader?
[Edited to add clarification]
