Using Balena Etcher 1.5.112 I get a failure at flashing a 128Gb SD card with an image created from a Raspberry Pi 128Gb SD card system.
Below are the snippets of the log output when the failure occurs (I’ve not included all of the log entries showing the successful writes up to the point of failure)
[51216:1210/135145.562550:INFO:CONSOLE(6038)] “Flashing 1 device, 99% at 55.40 MB/s (total 55.40 MB/s) eta in 7s with 0 failed devices”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (6038)
[51216:1210/135146.564230:INFO:CONSOLE(6038)] “Flashing 1 device, 99% at 56.40 MB/s (total 56.40 MB/s) eta in 6s with 0 failed devices”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (6038)
[51216:1210/135146.758971:INFO:CONSOLE(56878)] “Thu Dec 10 2020 13:51:46 GMT+0000 (Greenwich Mean Time) Input/output error ({“image”:{“size”:128177930240,“compressedSize”:11563684702,“hasMBR”:true,“path”:”/Users/ksaro1/Desktop/20201209_161116_pi_clone.gz",“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:127905300480,“type”:131,“index”:2}],“isCompressed”:true,“name”:“20201209_161116_pi_clone”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:127865454592,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk6",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk6",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk6",“busVersion”:null,“isSystem”:false,“busType”:“Secure Digital”,“isCard”:true,“isUSB”:false,“devicePath”:“IODeviceTree:/PCI0@0/RP10@1D,1/SDXC@0,1”,“mountpoints”:[{“path”:"/Volumes/boot",“label”:“boot”}],“description”:“Apple SDXC Reader Media”,“isUAS”:null,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“e6ca9510-c9af-4c55-a4f5-fdb2f3bac997”,“flashInstanceUuid”:“e6ca9510-c9af-4c55-a4f5-fdb2f3bac997”,“unmountOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“f2cbf9a9-af7d-48c0-ade6-c27a79e493aa”,“flashingWorkflowUuid”:“7f8acb00-b810-4f8b-b899-6e6b7d83333f”})", source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (56878)
[51216:1210/135147.568855:INFO:CONSOLE(6038)] “Flashing 0 devices, 99% at 56.90 MB/s (total 0.00 MB/s) eta in 6s with 1 failed device”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (6038)
[51216:1210/135201.053464:INFO:CONSOLE(56878)] “Finish: 127851823104”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (56878)
[51216:1210/135201.468415:INFO:CONSOLE(56878)] “Terminating IPC server”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (56878)
[51216:1210/135201.598249:INFO:CONSOLE(56878)] “Flash results [object Object]”, source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (56878)
[51216:1210/135201.832691:INFO:CONSOLE(56878)] “Thu Dec 10 2020 13:52:01 GMT+0000 (Greenwich Mean Time) Done ({“image”:{“size”:128177930240,“compressedSize”:11563684702,“hasMBR”:true,“path”:”/Users/ksaro1/Desktop/20201209_161116_pi_clone.gz",“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:127905300480,“type”:131,“index”:2}],“isCompressed”:true,“name”:“20201209_161116_pi_clone”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:127865454592,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk6",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk6",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk6",“busVersion”:null,“isSystem”:false,“busType”:“Secure Digital”,“isCard”:true,“isUSB”:false,“devicePath”:“IODeviceTree:/PCI0@0/RP10@1D,1/SDXC@0,1”,“mountpoints”:[{“path”:"/Volumes/boot",“label”:“boot”}],“description”:“Apple SDXC Reader Media”,“isUAS”:null,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“e6ca9510-c9af-4c55-a4f5-fdb2f3bac997”,“status”:“finished”,“flashInstanceUuid”:“e6ca9510-c9af-4c55-a4f5-fdb2f3bac997”,“unmountOnSuccess”:true,“errors”:[{“name”:“Error”,“description”:“Apple SDXC Reader Media”,“code”:“EIO”,“syscall”:“write”,“errno”:-5,“device”:"/dev/disk6"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:127851823104,“sourceMetadata”:{“isCompressed”:true,“name”:“20201209_161116_pi_clone”,“size”:127851823104,“compressedSize”:11563684702,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“f2cbf9a9-af7d-48c0-ade6-c27a79e493aa”,“flashingWorkflowUuid”:“7f8acb00-b810-4f8b-b899-6e6b7d83333f”})", source: file:///Applications/balenaEtcher.app/Contents/Resources/app/generated/gui.js (56878)
