I have an electron app running on resin and i t keeps crashing and restarting with these messages.
Hi, I met this issue before - related to the corruption of supervisor database.
If the supervisor database is corrupted, you can recreate it with the following commands in the Host OS:
# Stop supervisor and re-create a new database
systemctl stop resin-supervisor
rm /resin-data/resin-supervisor/database.sqlite
systemctl start resin-supervisor
The supervisor will re-create a new database. Hope this will solve your trouble. Good luck!
Hi @BrianL is there anything out of the ordinary when you check the supervisor logs?
journalctl --no-pager -u resin-supervisor
ran from the host OS webterminal would fetch you these logs.
