Hi Resin.io Forum!
I’m currently working on a project to turn a LoPy into a Raspberry Pi 3 controlled LoRa gateway, connected up using Node Red.
I’ve got Node Red running on the board now, using https://github.com/resin-io-projects/resin-node-red but now I want to get an MQTT Broker also running on the board simultaneously.
Does anyone have any suggestions as to what the best way to do this might be?
Alex
Hey @bucknalla, I’ve never used node-red before, but basically you just need to set up a broker that runs along side the node-red server? And then node-red has a built in UI to connect to a specific broker on a specific host:port as a client right?
To run the broker similtaneously you’ll need to install a broker in the build step and then in the resin-node-red start script you should and another line to start it along with node-red.
This should help get you get the broker installed and running https://www.rs-online.com/designspark/building-distributed-node-red-applications-with-mqtt
Hi @craig,
That’s right, I want a broker that runs alongside the node-red server.
Fantastic! That link looks great, seems to cover all my questions!
Cheers!
Alex
Hey Alex - how did you go with this? Could you share the Dockerfile as I’m also wanting to have mqtt running as a broker on the Pi?
Cheers
Darren
