hi,
I recently install Balena-cloud on a Rpi3 in a sd 16Go
I see my sorage at 170Mb and is allraedy full
I see the partion be at 14Go > how to have the fuill space disk ?
root@aec37a1:~# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 449M 0 449M 0% /dev
tmpfs 486M 4.0K 486M 1% /tmp
/dev/mmcblk0p2 307M 235M 53M 82% /mnt/sysroot/active
/dev/disk/by-state/resin-state 19M 394K 17M 3% /mnt/state
none 307M 235M 53M 82% /
/dev/mmcblk0p6 170M 141M 17M 90% /mnt/data
tmpfs 486M 24K 486M 1% /dev/shm
tmpfs 486M 8.9M 477M 2% /run
tmpfs 486M 0 486M 0% /sys/fs/cgroup
tmpfs 486M 20K 486M 1% /var/volatile
/dev/mmcblk0p1 40M 8.5M 31M 22% /mnt/boot
/dev/mmcblk0p3 307M 2.1M 285M 1% /mnt/sysroot/inactive
Disk /dev/mmcblk0: 14.64 GiB, 15707668480 bytes, 30679040 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xbb6525ed
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 * 8192 90111 81920 40M c W95 FAT32 (LBA)
/dev/mmcblk0p2 90112 745471 655360 320M 83 Linux
/dev/mmcblk0p3 745472 1400831 655360 320M 83 Linux
/dev/mmcblk0p4 1400832 30679039 29278208 14G f W95 Ext’d (LBA)
/dev/mmcblk0p5 1409024 1449983 40960 20M 83 Linux
/dev/mmcblk0p6 1458176 30679039 29220864 14G 83 Linux
tanks for your help
