Thanks @AlexProgrammerDE here it is:
Regards, @roj
@roj ok thats weird. Everything should work. Can you restart the container and give me the first logs you get?
@roj can you just give me the download of the logs?
@roj hmmmm. Can you try to manually put the paper.jar on the Pi?
@AlexProgrammerDE Can you please explain how to do that?
@roj oh no. Sorry for the really late answer. Download the latest build: https://papermc.io/downloads Then connect to the Pi as described in the blog post and then replace the paper.jar file with the file you just downloaded. Make sure the file name of both is paper.jar
Thanks @AlexProgrammerDE but my question was mischievously rhetorical.
I did that and everything worked out fine. @roj
Oh ok.
I need some help when I run the server after updating it by deleting all serverfiles in the server files folder and pushing the code. (I wanted to start fresh) It says that it can’t open paper.jar, when I run a scan of finding the file nothing appeared. What should I do??
Sorry, I’ve moved on since then and cannot recall my solutions without going back over old ground.
Suggest you contact @AlexProgrammerDE as it was his project
I hope you manage to resolve your problem.
Hi @THELITTLE ! So i think you deleted your server jar. You may wanna download a new one and run again. The url is https://papermc.io/ the file name must be paper.jar
Thx. And I am guessing I just put it onto the server files folder right??
