project not showing up on dashboard
i made a Minecraft sever but its not showing up on the dashboard, so I can’t access the console, is there a fix without starting from the beginning?
Hey @rohan welcome to the forum! It depends if you joined the open fleet or deployed it manually to your own account. Currently if you joined the open fleet there’s no way to access the console so if you need to use the terminal you’d have to deploy it again to a fleet created in your own account. There are instructions on the repo for doing that here: GitHub - AlexProgrammerDE/balena-minecraft-server: Build a Minecraft Server using a Raspberry Pi 4! Supports common Servers, SCP, RCON and Wifi Connect.
