Hi!
I got my hands on this R11e_LTE (it actually came inside the hAP router encosing, but I removed the modem with antennas)
Wanted to try it out as the mPCIe modem for BalenaFin. I connected it, created /system-connections/cellular configuration:
[connection]
id=cellular
type=gsm
autoconnect=true
[gsm]
apn=internet.emt.ee
number=*99#
[serial]
baud=115200
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
I also have a resin-wifi configuration there for my hotspot if that’s relevant.
After the device boots, I wait for a while with hotspot disabled, to see if it connects to cloud, but it does not. Then I enable the hotspot and SSH into the device.
NetworkManager journal has this:
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.3598] device (ttyACM1): Activation: starting connection 'cellular' (a12beb5c-487c-32e7-8638-d117416a5772)
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.3619] device (ttyACM1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.3773] modem["ttyACM1"]: modem state changed, 'registered' --> 'connecting' (reason: user-requested)
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.4177] modem["ttyACM1"]: modem state changed, 'connecting' --> 'registered' (reason: user-requested)
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.4309] modem["ttyACM1"]: modem state changed, 'registered' --> 'connecting' (reason: user-requested)
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.5304] modem["ttyACM1"]: modem state changed, 'connecting' --> 'registered' (reason: user-requested)
Oct 17 08:30:17 306549e NetworkManager[3947]: <warn> [1571301017.5306] modem-broadband[ttyACM1]: failed to connect modem: "0 Unknown"
Oct 17 08:30:17 306549e NetworkManager[3947]: <info> [1571301017.5312] device (ttyACM1): state change: prepare -> failed (reason 'unknown', sys-iface-state: 'managed')
mmcli -m 0:
method=autoroot@306549e:~# mmcli -m 0
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: caee662fedf2c9f9c27e4db382ed5dab4d41c1a5
Hardware | manufacturer: MikroTik
| model: R11e-LTE
| firmware revision: MikroTik_CP_2.160.000_v012
| supported: gsm-umts
| current: gsm-umts
| equipment id: 355654091546593
System | device: /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2
| drivers: cdc_acm, rndis_host
| plugin: Generic
| primary port: ttyACM1
| ports: eth1 (net), ttyACM1 (at)
Status | state: registered
| power state: on
| access tech: lte
| signal quality: 0% (recent)
Modes | supported: allowed: any; preferred: none
| current: allowed: any; preferred: none
IP | supported: ipv4, ipv6
3GPP | imei: 355654091546593
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
Bearer | dbus path: /org/freedesktop/ModemManager1/Bearer/17057
Also:
root@306549e:~# nmcli device show ttyACM1
GENERAL.DEVICE: ttyACM1
GENERAL.TYPE: gsm
GENERAL.HWADDR: (unknown)
GENERAL.MTU: 0
GENERAL.STATE: 40 (connecting (prepare))
GENERAL.CONNECTION: cellular
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/9152
NOTE: I am able to use mmcli to successfully send SMS and receive it on my phone, so at least that part of the thing works.
I’m total NOOB regarding cellular in linux, so I’m open to all kinds of ideas and I hope that this is something trivial that I’m missing, but of course, as the hw is not officially supported, then it could be that
