i have issues with my internet connection via the quectel ec-25e modem. mmcli -m -0
shows that my modem is somehow connected to the mobile network:
But there is no internet connection to connect to the balena cloud. When i type nmcli dev status
i get:
What is wrong with my connection? Why is my modem marked as disconnected? Why does it not connect on start up?
thank you for your question which lead me to a problem with the connection file.
If i connect the fin to my pc(window 10) via usb, i can see and open the connection file which i called “cellular”. Like in the docu (https://www.balena.io/docs/reference/OS/network/2.x/#cellular-modem-setup)
When i connect the fin to balena cloud via ethernet and open the file system via the terminal i can’t see the file anymore.
Hi there, since /resin-boot is a copy of the boot files that end up in the boot partition and the real currently running boot files are in /mnt/boot , could you please check if the file is available in / mnt / boot / system-connections?
