I tried to copy an image file
from a gzip’s image (dd) file of a raspberrypi boot drive
to an sd card
on 2 different pcs (win10 and win11)
Based on the log, the write seems to be ok, but the verify fails. The only message I see is “Flash Failed” in the gui.
Here’s the log starting at the end of the verify…
Verifying 1 device, 99% at 75.80 MB/s (total 75.80 MB/s) eta in 2s with 0 failed devices
gui.js:35 Verifying 1 device, 99% at 78.40 MB/s (total 78.40 MB/s) eta in 1s with 0 failed devices
gui.js:46 Mon Sep 05 2022 15:51:41 GMT-0400 (Eastern Daylight Time) Validation error ({“image”:{“size”:15590227968,“compressedSize”:3561584641,“hasMBR”:true,“path”:“R:\util\dd_raspberrypi0_v8.img.gz”,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:15317598208,“type”:131,“index”:2}],“isCompressed”:true,“name”:“dd_raspberrypi0_v8.img”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:15590227968,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Generic STORAGE DEVICE USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“02944dab-7e6e-4a84-b3e5-19a5445f0269”,“flashInstanceUuid”:“02944dab-7e6e-4a84-b3e5-19a5445f0269”,“sample”:0.1,“applicationSessionUuid”:“93082fba-7044-4e85-b08f-b3918dedf54d”,“flashingWorkflowUuid”:“ecd08f0b-da30-48cc-8064-ce1b90060a8b”})
gui.js:35 Verifying 1 device, 100% at 78.90 MB/s (total 78.90 MB/s) eta in 0s with 0 failed devices
gui.js:46 Finish: 15590227968
gui.js:46 Terminating IPC server
gui.js:46 Flash results Object
gui.js:46 Mon Sep 05 2022 15:51:45 GMT-0400 (Eastern Daylight Time) Done ({“image”:{“size”:15590227968,“compressedSize”:3561584641,“hasMBR”:true,“path”:“R:\util\dd_raspberrypi0_v8.img.gz”,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:15317598208,“type”:131,“index”:2}],“isCompressed”:true,“name”:“dd_raspberrypi0_v8.img”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:15590227968,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:“Generic STORAGE DEVICE USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“02944dab-7e6e-4a84-b3e5-19a5445f0269”,“status”:“finished”,“flashInstanceUuid”:“02944dab-7e6e-4a84-b3e5-19a5445f0269”,“errors”:[{“name”:“Error”,“description”:“Generic STORAGE DEVICE USB Device”,“code”:“EVALIDATION”,“device”:“\\.\PhysicalDrive1”}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:15590227968,“sourceMetadata”:{“isCompressed”:true,“name”:“dd_raspberrypi0_v8.img”,“size”:15590227968,“compressedSize”:3561584641,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“93082fba-7044-4e85-b08f-b3918dedf54d”,“flashingWorkflowUuid”:“ecd08f0b-da30-48cc-8064-ce1b90060a8b”})
gui.js:46 Mon Sep 05 2022 15:51:45 GMT-0400 (Eastern Daylight Time) SafeWebview loaded ({“event”:{“id”:48,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.9&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1662407505546.267,“resourceType”:“mainFrame”,“ip”:“34.74.37.249”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“25042”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“gzip”],“content-length”:[“7279”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Mon, 05 Sep 2022 12:54:23 GMT”],“etag”:[“"269ee492d4b6ca6c9c6be34c6d490ab2-ssl-df"”],“link”:[“</webpack-runtime-631869ea8900f563b847.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-4b6d12e0d352a4f78d5a.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-cea6bfcc846ea7ff6166.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin”],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01GC7KAXCN3PCWGW5VQ8QA7XMG”],“x-xss-protection”:[“1; mode=block”]},“referrer”:“”,“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“93082fba-7044-4e85-b08f-b3918dedf54d”,“flashingWorkflowUuid”:“ecd08f0b-da30-48cc-8064-ce1b90060a8b”})
gui.js:46 Mon Sep 05 2022 15:59:51 GMT-0400 (Eastern Daylight Time) Open external link ({“url”:“balenaEtcher - Flash OS images to SD cards & USB drives”})
