Greetings,
Currently, when I try to see logs in the dashboard it just indefinitely shows “Loading logs…”.
When I try to get them via command line, the following error is shown:
PubNub call failed, check status for details
If you need help, don't hesitate in contacting us at:
GitHub: https://github.com/resin-io/resin-cli/issues/new
Forums: https://forums.balena.io
I do not know which or how to check the status. Is this a problem with our devices? Could you help me debug it? It occurs on all our devices and a reboot does not fix it. Is it a problem on resins side?
Appreciate the help,
Greetings, Tarek
Hi @Tschebbischeff. Yes, we’re currently experiencing problems with logging, due to upstream issues with PubNub: http://uptime.pubnub.com/. This is temporary, but they’re investigating, and hopefully this will be resolved soon.
You can check the status of Resin’s infrastructure (and sign up for notifications in future) here: https://status.resin.io/.
Thank you,
I see now which status was meant in the command line.
I actually checked that before and it was all green, thats why I wondered if it might be an error with our devices. I guess my timing just sucks
Thanks for the clarification and ultra fast reply
. Have a nice day!
Everything should be fully operational now.
Please give us a note if you are still facing issues.
