Logic Supply CL100 support
We have some NUC factor based logic supply based hardware. It is a Logicsupply CL100
https://www.logicsupply.com/eu-en/products/industrial-computers/cl100-series/
The Intel NUC image seems to work ok, but there is no correct graphics driver loaded for this platform. It should load the i915 module, but that is not available in the Intel NUC image.
What would be the best way to add this driver?
So after some hacking i got the UP image working on this device. This seems to load the i915 module, but still using the
There is still no HW accelerations.
What does work (with HW acces) on both images (NUC/UP) and just plain Ubuntu Server LTS with docker is running a container like this:
docker -H <device ip> run -it --name hw-image --privileged -v /var/run/dbus:/var/run/dbus -v /var/run/udev:/var/run/udev -d  -v /mnt/data/hw-image:/data hw-image startx
Using this Dockerfile
FROM ubuntu
# Install other apt deps
  apt-utils \
  clang \
  xserver-xorg-core \
  xserver-xorg-input-all \
  xserver-xorg-video-fbdev \
  xorg \
  xserver-xorg-video-intel \
  mesa-utils \
  mesa-utils-extra \
  fluxbox \
  libexpat-dev && rm -rf /var/lib/apt/lists/*
# Set Xorg and FLUXBOX preferences
RUN mkdir ~/.fluxbox
#RUN echo "xset s off" > ~/.fluxbox/startup && echo "xserver-command=X -s 0 dpms" >> ~/.fluxbox/startup
RUN echo "#!/bin/bash" > /etc/X11/xinit/xserverrc \
  && echo "" >> /etc/X11/xinit/xserverrc \
  && echo 'exec /usr/bin/X -nolisten tcp "$@"' >> /etc/X11/xinit/xserverrc
#  && echo 'exec /usr/bin/X -s 0 dpms -nolisten tcp "$@"' >> /etc/X11/xinit/xserverrc
# Move to app dir
WORKDIR /usr/src/app
# Move package.json to filesystem
COPY ./app/package.json ./
# Install npm modules for the application
#RUN JOBS=MAX npm install --unsafe-perm --production \
#	&& npm cache clean && node_modules/.bin/electron-rebuild
    firefox \
    chromium-browser \
    fbset \
    mpv \
    vlc
# Move app to filesystem
COPY ./app ./
## uncomment if you want systemd
ENV INITSYSTEM on
# Start app
CMD ["bash", "/usr/src/app/start.sh"]
So what’s going on there?
