Ah, those error messages may be OK, if they stop happening after “Device state settled” is printed. What may be happening (admittedly confusing) is that log messages printed by the “current” running container (which will be replaced by balena push) are mixed with balena push output for ongoing events…
Line by line:
[Logs] [2020-4-10 17:05:31] Restarting service ‘main ...
This means that balena-cli has started the procedure of restarting the current container…
@pdcastro I deleted the container so that I was starting afresh and tried to run with the parameters set up in the config.json file. I didn’t like seeing syntax and compile errors:
Just a quick check, because the config.json is being used instead now it looks like the line endings in it are not being converted, which is why jq complains about it here:
My assumption is that for some reason this file is not getting converted, I’m going to ping Paulo again just to confirm that every source/data file should be being converted, but for the meantime you may need to run a Windows to Unix line ending utility over the config.json and then retry. Could you let us know if that does solve the problem, as then it would point to balena CLI not doing this.
Yep, that absolutely looks like it should work to me! What’s also confusing having looked a bit more is that it’s complaining about line 1 for “refreshTime=” and yet in your config, that’s on about the 9th line. This seems extremely strange to me, as if the wrong config is being pulled in. There’s no other duplicate configs being pulled in, are their, or incorrect files being referenced in the Dockerfile?
@Nigel, I have tested using a config.json file and I got the jq error as well, same as you. It is not a CRLF / EOL issue – I actually tested with CRLF line endings too, and the --convert-eol option does its job just fine. Debugging it further, I found that the repo’s .gitignore file has a line listing “config.json”. I edited the .gitignore file, deleted the line that listed config.json, and then it worked. Actually, you could delete the .gitignore file altogether, at:
C:\balena\train-display\.gitignore
I am not sure whether this is a “project bug” and config.json should not have been listed in the .gitignore file, or whether it was my mistake to advise you to use the config.json file in the first place - I’ve asked the project maintainer for his view, and created a GitHub issue on the project repo.
So, deleting the .gitignore file might do the trick for now. (In case you wonder: the CLI looks at both the .gitignore and .dockerignore files to decide what to push to devices or to the cloud. There are plans to change this so the CLI stops looking at the .gitignore file, but currently it takes both ignore files into account.)
Otherwise:
The following also worked for me (or at least it avoided the jq error for refreshTime, and of course I am using my own IP address…):
If you still come across further such errors, try adding the echo and print lines that I mentioned in a previous message, to isolate where the issue is.
I deleted the .gitignore file and added the suggested debug print statements:
@Nigel, sorry, besides deleting the .gitignore file, there was another change that I had made for my “successful test”, which I forgot to mention. I had also edited the Dockerfile.template file to replace the following line:
He replied, explaining he had always used the long command line with the --env arguments, instead of using a config.json file. The logic coded in the balena-run.sh script had not been tested with a config.json file, hence the issues with the .gitignore and Dockerfile.template files. So it looks like using the config.json file is to walk off the beaten path, and if you continue to experience issues, you may prefer to go back to the long command line with --env arguments.
@pdcastro, OK, it works with the --env arguments passed in the command line. What a joy to see it run with no errors! Now I have a stable refence, I can procede. Thanks for staying with me with this problem.
