Having succesfully deployed an app using the Cloud I thought I would try Local Mode. I followed the instructions and it all appeared to be progressing, but it ended with an error which just repeated. See below:
PS C:\balena\train-display> balena push 192.168.1.24
[Info] Starting build on device 192.168.1.24
[Info] No "docker-compose.yml" file found at "."
[Info] Creating default composition with source: "."
[Warn] CRLF detection skipped for large file: C:\balena\train-display\balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-v10.6.27.img (1).zip
[Warn] CRLF detection skipped for large file: C:\balena\train-display\balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-v10.6.27.img.zip
[Warn] CRLF detection skipped for large file: C:\balena\train-display\old_balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-v10.6.27.img.zip
[Warn] CRLF detection skipped for large file: C:\balena\train-display\balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-dev-v10.6.27.img.zip
[Warn] CRLF detection skipped for large file: C:\balena\train-display\balena-cloud-Train_Display-raspberrypi3-2.47.0+rev1-v10.6.27.img.zip
[Warn] CRLF detection skipped for large file: C:\balena\train-display\balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-v10.6.27.img (2).zip
[Warn] CRLF (Windows) line endings detected in file: C:\balena\train-display\example_balena_wifi_setup.txt
[Warn] CRLF detection skipped for large file: C:\balena\train-display\new_balena-cloud-Train_Display-raspberry-pi-2.46.1+rev1-v10.6.27.img.zip
[Build] [main] Step 1/12 : FROM balenalib/raspberry-pi-debian-python:3.7-buster-build
[Build] [main] ---> 31b9693234ae
[Build] [main] Step 2/12 : RUN install_packages jq moreutils libopenjp2-7 libfreetype6-dev libjpeg-dev libtiff5
[Build] [main] ---> Running in 0e2ca6d0dad3
[Build] [main] Reading package lists...
[Build] [main] Building dependency tree...
[Build] [main] Reading state information...
[Build] [main] libjpeg-dev is already the newest version (1:1.5.2-2).
[Build] libopenjp2-7 is already the newest version (2.3.0-2+deb10u1).
[Build] libopenjp2-7 set to manually installed.
[Build] libtiff5 is already the newest version (4.1.0+git191117-2~deb10u1).
[Build] libtiff5 set to manually installed.
[Build] The following additional packages will be installed:
[Build] [main] libio-pty-perl libipc-run-perl libjq1 libonig5 libpng-dev
[Build] [main] Suggested packages:
[Build] [main] freetype2-doc libtime-duration-perl libtimedate-perl
[Build] [main] Recommended packages:
[Build] libpng-tools
[Build] [main] The following NEW packages will be installed:
[Build] [main] jq libfreetype6-dev libio-pty-perl libipc-run-perl libjq1 libonig5
[Build] [main] libpng-dev moreutils
[Build] [main] 0 upgraded, 8 newly installed, 0 to remove and 5 not upgraded.
[Build] Need to get 1292 kB of archives.
[Build] After this operation, 4275 kB of additional disk space will be used.
[Build] Get:1 http://archive.raspbian.org/raspbian buster/main armhf libonig5 armhf 6.9.1-1 [150 kB]
[Build] [main] Get:2 http://archive.raspbian.org/raspbian buster/main armhf libjq1 armhf 1.5+dfsg-2+b1 [119 kB]
[Build] [main] Get:3 http://archive.raspbian.org/raspbian buster/main armhf jq armhf 1.5+dfsg-2+b1 [59.3 kB]
[Build] [main] Get:4 http://archive.raspbian.org/raspbian buster/main armhf libpng-dev armhf 1.6.36-6 [281 kB]
[Build] [main] Get:5 http://archive.raspbian.org/raspbian buster/main armhf libfreetype6-dev armhf 2.9.1-3+deb10u1 [479 kB]
[Build] [main] Get:6 http://archive.raspbian.org/raspbian buster/main armhf libio-pty-perl armhf 1:1.08-1.1+b4 [33.0 kB]
[Build] [main] Get:7 http://archive.raspbian.org/raspbian buster/main armhf libipc-run-perl all 20180523.0-1 [101 kB]
[Build] [main] Get:8 http://archive.raspbian.org/raspbian buster/main armhf moreutils armhf 0.62-1+b1 [69.3 kB]
[Build] [main] debconf: delaying package configuration, since apt-utils is not installed
[Build]
[Build] [main] Fetched 1292 kB in 1s (1483 kB/s)
[Build] [main] Selecting previously unselected package libonig5:armhf.
[Build] [main]
[Build] (Reading database ...
[Build] [main] (Reading database ... 5%
[Build] [main] (Reading database ... 10%
[Build] [main] (Reading database ... 15%
[Build] [main] (Reading database ... 20%
[Build] [main] (Reading database ... 25%
[Build] [main] (Reading database ... 30%
[Build] [main] (Reading database ... 35%
(Reading database ... 55% database ... 40%
(Reading database ... 90% database ... 60%
(Reading database ... 20403 files and directories currently installed.)
[Build] [main] Preparing to unpack .../0-libonig5_6.9.1-1_armhf.deb ...
[Build] [main] Unpacking libonig5:armhf (6.9.1-1) ...
[Build] [main] Selecting previously unselected package libjq1:armhf.
[Build] [main] Preparing to unpack .../1-libjq1_1.5+dfsg-2+b1_armhf.deb ...
[Build] [main] Unpacking libjq1:armhf (1.5+dfsg-2+b1) ...
[Build] [main] Selecting previously unselected package jq.
[Build] [main] Preparing to unpack .../2-jq_1.5+dfsg-2+b1_armhf.deb ...
[Build] [main] Unpacking jq (1.5+dfsg-2+b1) ...
[Build] [main] Selecting previously unselected package libpng-dev:armhf.
[Build] [main] Preparing to unpack .../3-libpng-dev_1.6.36-6_armhf.deb ...
[Build] [main] Unpacking libpng-dev:armhf (1.6.36-6) ...
[Build] [main] Selecting previously unselected package libfreetype6-dev:armhf.
[Build] [main] Preparing to unpack .../4-libfreetype6-dev_2.9.1-3+deb10u1_armhf.deb ...
[Build] [main] Unpacking libfreetype6-dev:armhf (2.9.1-3+deb10u1) ...
[Build] [main] Selecting previously unselected package libio-pty-perl.
[Build] [main] Preparing to unpack .../5-libio-pty-perl_1%3a1.08-1.1+b4_armhf.deb ...
[Build] [main] Unpacking libio-pty-perl (1:1.08-1.1+b4) ...
[Build] [main] Selecting previously unselected package libipc-run-perl.
[Build] [main] Preparing to unpack .../6-libipc-run-perl_20180523.0-1_all.deb ...
[Build] [main] Unpacking libipc-run-perl (20180523.0-1) ...
[Build] [main] Selecting previously unselected package moreutils.
[Build] [main] Preparing to unpack .../7-moreutils_0.62-1+b1_armhf.deb ...
[Build] [main] Unpacking moreutils (0.62-1+b1) ...
[Build] [main] Setting up libio-pty-perl (1:1.08-1.1+b4) ...
[Build] [main] Setting up libpng-dev:armhf (1.6.36-6) ...
[Build] [main] Setting up libfreetype6-dev:armhf (2.9.1-3+deb10u1) ...
[Build] [main] Setting up libipc-run-perl (20180523.0-1) ...
[Build] [main] Setting up libonig5:armhf (6.9.1-1) ...
[Build] [main] Setting up moreutils (0.62-1+b1) ...
[Build] [main] Setting up libjq1:armhf (1.5+dfsg-2+b1) ...
[Build] [main] Setting up jq (1.5+dfsg-2+b1) ...
[Build] [main] Processing triggers for libc-bin (2.28-10+rpi1) ...
[Build] [main] Removing intermediate container 0e2ca6d0dad3
[Build] [main] ---> d5ff28bd910d
[Build] [main] Step 3/12 : WORKDIR /usr/app
[Build] [main] ---> Running in cdc37b2ea228
[Build] [main] Removing intermediate container cdc37b2ea228
[Build] [main] ---> 3cd440f258de
[Build] [main] Step 4/12 : COPY ./requirements.txt .
[Build] [main] ---> 53615d4a2b87
[Build] [main] Step 5/12 : RUN pip install -r requirements.txt
[Build] [main] ---> Running in e794b340a980
[Build] [main] Collecting luma.oled
[Build] [main] Downloading https://files.pythonhosted.org/packages/b0/fa/ef1065ad3644608d6127ce05da43b2b6ab1857b5b26983439f696bab6f4a/luma.oled-3.4.0-py2.py3-none-any.whl
[Build] [main] Collecting timeloop
[Build] [main] Downloading https://files.pythonhosted.org/packages/6a/95/3e39ee32f15a8e9dea46bb52300611a5351964eeaa393bafb0d738e90ce0/timeloop-1.0.2.tar.gz
[Build] [main] Collecting requests
[Build] [main] Using cached https://files.pythonhosted.org/packages/1a/70/1935c770cb3be6e3a8b78ced23d7e0f3b187f5cbfab4749523ed65d7c9b1/requests-2.23.0-py2.py3-none-any.whl
[Build] [main] Collecting luma.core>=1.12.0
[Build] [main] Downloading https://files.pythonhosted.org/packages/90/51/ae30ce7c3ef0698547b77cb3263f17f49345f33e360af8032f86c0f6dcf6/luma.core-1.14.0-py2.py3-none-any.whl (51kB)
[Build] [main] Collecting idna<3,>=2.5
[Build] [main] Using cached https://files.pythonhosted.org/packages/89/e3/afebe61c546d18fb1709a61bee788254b40e736cff7271c7de5de2dc4128/idna-2.9-py2.py3-none-any.whl
[Build] [main] Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
[Build] [main] Using cached https://files.pythonhosted.org/packages/e8/74/6e4f91745020f967d09332bb2b8b9b10090957334692eb88ea4afe91b77f/urllib3-1.25.8-py2.py3-none-any.whl
[Build] [main] Collecting certifi>=2017.4.17
[Build] [main] Using cached https://files.pythonhosted.org/packages/57/2b/26e37a4b034800c960a00c4e1b3d9ca5d7014e983e6e729e33ea2f36426c/certifi-2020.4.5.1-py2.py3-none-any.whl
[Build] [main] Collecting chardet<4,>=3.0.2
[Build] [main] Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
[Build] [main] Collecting pillow>=4.0.0
[Build] [main] Downloading https://files.pythonhosted.org/packages/c7/04/c91bb0e495c1e8a09633ecb061fab32e276ace7cefcef5d12334cdd14cd2/Pillow-7.1.1.tar.gz (38.9MB)
[Build] [main] Collecting RPI.GPIO; platform_system == "Linux"
[Build] [main] Downloading https://files.pythonhosted.org/packages/cb/88/d3817eb11fc77a8d9a63abeab8fe303266b1e3b85e2952238f0da43fed4e/RPi.GPIO-0.7.0.tar.gz
[Build] [main] Collecting spidev; platform_system == "Linux"
[Build] [main] Downloading https://files.pythonhosted.org/packages/fb/14/4c2e1640f0cb04862c76d9d76ed7c945b0f67876e503ac02f7f675fe86a0/spidev-3.4.tar.gz
[Build] [main] Collecting smbus2
[Build] [main] Downloading https://files.pythonhosted.org/packages/6a/06/80a6928e5cbfd40c77c08e06ae9975c2a50109586ce66435bd8166ce6bb3/smbus2-0.3.0.tar.gz
[Build] [main] Collecting pyftdi
[Build] [main] Downloading https://files.pythonhosted.org/packages/ee/7c/7b6c705b60159806c073e5539a233813f10b1c0c9a11a824b1a27ddddaad/pyftdi-0.50.0-py36-none-any.whl (148kB)
[Build] [main] Collecting pyusb>=1.0.0
[Build] [main] Downloading https://files.pythonhosted.org/packages/5f/34/2095e821c01225377dda4ebdbd53d8316d6abb243c9bee43d3888fa91dd6/pyusb-1.0.2.tar.gz (54kB)
[Build] [main] Collecting pyserial>=3.0
[Build] [main] Downloading https://files.pythonhosted.org/packages/0d/e4/2a744dd9e3be04a0c0907414e2a01a7c88bb3915cbe3c8cc06e209f59c30/pyserial-3.4-py2.py3-none-any.whl (193kB)
[Build] [main] Installing collected packages: pillow, RPI.GPIO, spidev, smbus2, pyusb, pyserial, pyftdi, luma.core, luma.oled, timeloop, idna, urllib3, certifi, chardet, requests
[Build] [main] Running setup.py install for pillow: started
[Build] [main] Running setup.py install for pillow: still running...
[Build] [main] Running setup.py install for pillow: finished with status 'done'
[Build] [main] Running setup.py install for RPI.GPIO: started
[Build] [main] Running setup.py install for RPI.GPIO: finished with status 'done'
[Build] [main] Running setup.py install for spidev: started
[Build] [main] Running setup.py install for spidev: finished with status 'done'
[Build] [main] Running setup.py install for smbus2: started
[Build] [main] Running setup.py install for smbus2: finished with status 'done'
[Build] [main] Running setup.py install for pyusb: started
[Build] [main] Running setup.py install for pyusb: finished with status 'done'
[Build] [main] Running setup.py install for timeloop: started
[Build] [main] Running setup.py install for timeloop: finished with status 'done'
[Build] [main] Successfully installed RPI.GPIO-0.7.0 certifi-2020.4.5.1 chardet-3.0.4 idna-2.9 luma.core-1.14.0 luma.oled-3.4.0 pillow-7.1.1 pyftdi-0.50.0 pyserial-3.4 pyusb-1.0.2 requests-2.23.0 smbus2-0.3.0 spidev-3.4 timeloop-1.0.2 urllib3-1.25.8
[Build] [main] WARNING: You are using pip version 19.3.1; however, version 20.0.2 is available.
[Build] You should consider upgrading via the 'pip install --upgrade pip' command.
[Build]
[Build] [main] Removing intermediate container e794b340a980
[Build] [main] ---> ef6fb43899b5
[Build] [main] Step 6/12 : COPY src ./src
[Build] [main] ---> 7b18b8c2e6ec
[Build] [main] Step 7/12 : COPY balena-run.sh ./
[Build] [main] ---> 83f7c256db99
[Build] [main] Step 8/12 : COPY config.sample.json ./
[Build] [main] ---> 4fb3247a80e9
[Build] [main] Step 9/12 : RUN chmod +x balena-run.sh
[Build] [main] ---> Running in 922723af3244
[Build] [main] Removing intermediate container 922723af3244
[Build] [main] ---> 50b398e68e2e
[Build] [main] Step 10/12 : CMD ./balena-run.sh
[Build] [main] ---> Running in ef069c042f10
[Build] [main] Removing intermediate container ef069c042f10
[Build] [main] ---> 1309d4088c73
[Build] [main] Step 11/12 : LABEL io.resin.local.image=1
[Build] [main] ---> Running in a30852ddd483
[Build] [main] Removing intermediate container a30852ddd483
[Build] [main] ---> 4f5e966c77ce
[Build] [main] Step 12/12 : LABEL io.resin.local.service=main
[Build] [main] ---> Running in 01aa8d938e45
[Build] [main] Removing intermediate container 01aa8d938e45
[Build] [main] ---> 454c5b68bd40
[Build] [main] Successfully built 454c5b68bd40
[Build] [main] Successfully tagged local_image_main:latest
[Live] Waiting for device state to settle...
[Info] Streaming device logs...
[Live] Watching for file changes...
[Warn] Windows-format line endings were detected in some files. Consider using the `--convert-eol` option.
[Logs] [2020-4-8 12:11:27] Creating volume 'resin-data'
[Logs] [2020-4-8 12:11:27] Creating network 'default'
[Logs] [2020-4-8 12:11:28] Installing service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:11:30] Installed service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:11:30] Starting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:11:41] Started service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:11:39] [main] .refreshTime=
[Logs] [2020-4-8 12:11:39] [main] jq: error: syntax error, unexpected $end (Unix shell quoting issues?) at <top-level>, line 1:
[Logs] [2020-4-8 12:11:39] [main] jq: 1 compile error
[Logs] [2020-4-8 12:11:53] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:12:03] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:12:23] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Live] Device state settled
[Logs] [2020-4-8 12:12:29] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:12:34] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:12:43] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:12:48] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:12:55] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:13] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:18] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:13:23] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:33] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:38] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:13:43] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:52] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:13:58] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:14:02] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:12] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:17] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:14:22] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:31] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:36] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:14:41] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:52] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:14:57] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:15:02] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:15:11] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:15:16] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:15:20] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:15:30] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:15:40] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:15:48] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:05] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:10] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:16:15] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:25] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:30] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:16:35] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:44] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:16:49] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:16:53] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:03] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:08] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:17:13] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:23] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:29] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:17:33] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:45] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:17:52] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:17:56] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:09] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:19] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:18:24] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:34] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:39] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:18:44] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:53] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:18:58] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:19:03] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:19:19] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:19:29] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:19:39] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:19:49] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:19:54] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:19:58] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:20:07] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:20:13] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:20:20] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:20:27] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:20:32] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:22:38] Service exited 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:22:38] Restarting service 'main sha256:454c5b68bd40a5764fea9e90b69b61c8257a8228b73e18277e2636bfda150afa'
[Logs] [2020-4-8 12:20:50] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:21:11] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:21:31] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:21:51] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:22:13] [main] Error: Expecting value: line 1 column 1 (char 0)
[Logs] [2020-4-8 12:22:33] [main] Error: Expecting value: line 1 column 1 (char 0)
