Thanks for confirming Sven, looking at the device logs it seems part of the issue relates to a 404 from our delta server, to check this I’ve disabled delta updates in the device configuration. Can you power cycle the device if possible please?
Hi Joe,
I used the command: “C:\balena-cli\balena deploy –-registry-secrets C:\Users\hasv\myimages\balena_moxa\secrets.yml sven_haugstetter/Test”
I´m using private registries
I have granted you access to the device
The first release was successful. All others failed.
Hello Joe,
I’m a colleague of Sebastian and I’m trying to update the containers on an Edge Device.
During the update I got stuck at 71% and nothing happens anymore. After some time the status changed from “Updating” to “Online” and the old release is still on the device.
Here are some screens and attached you´ll find the logfile. Maybe you have an idea how to fix that.
Thank you in advance.
Best regards,
Sven
