I am facing an issue while trying to use balena push with a device UUID instead of the application name. According to the Balena CLI documentation, it suggests that balena push can be used with the device UUID . However, when I try to push using balena push 8f4d6a2.local --system, I am getting the following error: ![]()
ENOTFOUND: getaddrinfo ENOTFOUND 8f4d6a2.local
I am using Balena CLI version 18.2.2. Am I missing something in my approach? I have checked balena CLI Documentation - Balena Documentation msbi documentation for guidance but still need help.
Could someone clarify if balena push supports pushing directly to a device using its UUID or if there’s a specific configuration needed?
Any help would be greatly appreciated. ![]()
Thank you!
stevediaz
