Hi guys,
I’ve noticed a few inconsistencies that have started to annoy me since I’ve noticed them. These are all in the ‘balena device’ subset of commands…
If we use balena devices, we get a list of devices. Good.
$ balena devices
ID UUID DEVICE NAME DEVICE TYPE APPLICATION NAME STATUS IS ONLINE SUPERVISOR VERSION OS VERSION
35 7341412 still-glitter jetson-nano triage Idle true 11.14.0 balenaOS 2.60.1+rev1
Now to bring up the information on that device, the help says:
$ balena help --verbose
USAGE
$ balena [COMMAND] [OPTIONS]
PRIMARY COMMANDS
devices list all devices
device <uuid>
Using the shortened UUID as per the output of balena devices, we get:
$ balena device 7341412
BalenaDeviceNotFound: Device not found: 7341412
Ok, what about the DEVICE NAME field… Nope:
$ balena device still-glitter
BalenaDeviceNotFound: Device not found: still-glitter
But when we use the ID:
$ balena device 35
== STILL GLITTER
DEVICE TYPE: jetson-nano
STATUS: idle
IS ONLINE: true
IP ADDRESS: 10.1.1.194
UUID: 73414124ca8ab35699814c985d555a02
So now we can get the full UUID, which also seems to work:
$ balena device 73414124ca8ab35699814c985d555a02
== STILL GLITTER
STATUS: idle
IS ONLINE: true
So, what should I suggest to make this command set logical and follow what the help actually states?
Should it also match the shortened UUID? Should the documentation / help say to use the ID and not UUID? Should it be something else?
Thanks in advance.
