Install package on Host OS Image
Hi All,
Just wondering how I would go about installing an application package such as vnstat on HostOS such that it is part of the base install when you flash a new device?
Cheers
Chris
Hello @dash,
you can’t add new applications to the HostOS as it could decrease the stability of the system.
You can only add it to a container.
Cheers
Thanks @dansku. I’ll have try work around it. It’s possible to run vnstat in a docker container and use privileged mode to give it the access it requires to host network interfaces but I feel privileged mode should be avoided.
Shouldn’t it be the user’s responsibility to not “decrease the stability of the system”? We just want to install htop.
Hello
You can do this by building balenaOS yourself. Take a look at our instructions for how to do so here
