Hi community,
I’m trying to update an InfluxDB service in my balena application.
Right now, I have InfluxDB 1.7.11 running without issues using this block in my docker-compose.yml:
influxdb:
image: influxdb:1.7.11
volumes:
- influxdb-data:/var/lib/influxdb
- influxdb-etc:/etc/influxdb
This works fine in balena local mode.
The problem comes when I try to switch to InfluxDB 2.x (for example influxdb:2.7). I tried:
influxdb:
image: influxdb:2.7
ports:
- "8086:8086"
volumes:
- influxdb-data:/var/lib/influxdb2
- influxdb-config:/etc/influxdb2
environment:
DOCKER_INFLUXDB_INIT_MODE: setup
DOCKER_INFLUXDB_INIT_USERNAME: admin
DOCKER_INFLUXDB_INIT_PASSWORD: admin123
DOCKER_INFLUXDB_INIT_ORG: myorg
DOCKER_INFLUXDB_INIT_BUCKET: mybucket
But when I run balena push <device>.local I get this error:
data should NOT have additional properties
I’ve already tried removing container_name, restart, and changing the environment format, but the error persists.
Has anyone successfully run InfluxDB 2.x on balena?
Is there any specific restriction in docker-compose.yml for this version?
Thanks in advance ![]()
