I flashed HIVE OS onto an external SSD and is no longer visible. I can only see it in the disk manager but I cant even access it to set the rig file for mining. Any solution? all help is greatly appreciated.
Hello, I’m not familiar with Hive OS but from their installation instructions it says “After the image is flashed you will discover newly created drive in your system.” If you are using Windows you may need to mount it in the disk manager to access it. You may also find more information about that on the HiveOS forums. Is the SSD being flashed ultimately going into a different computer or mining rig and is the SSD supposed to be bootable?
