Failed to flash HIVEOS - 3 different ways
Ive tried all different ways - USB, M.2 Nvme and SSD Ive flashed as administrator yet every time 2% before the end of validating i get “Something went wrong” message. Ive started from scratch four different times and downloaded Hive OS Windows 10 x64 compressed, recompressed, uncompressed and again starting from scratch. Ive tried not validating but the software does not boot. The USB is new, the SSD ive used successfully on the same task and ive not used M.2 before but its all shows up in my BIOS.
Any ideas?
Are you trying to flash HiveOS directly onto an SSD or the flasher-installer onto a USB stick? Have you tried following these instructions: GitHub - minershive/hive-flasher: Hive OS Drive Flashing Utility
I’ll give it a go as I’m open to any suggestions
Sent using the GMX mail app
Thank you for your suggest. No luck I’m afraid. Etcher had been working well. I wondered when I renamed my drive letter for flashing Hive it may have caused issues.
I tried rufus, a slower pace, but without any problems.
Very strange.
Many thanks for your input
Regards
Gerald
