I posted this on Stack Overflow and thought I would cross-post the content here as well. Inspired by the original blog post by @imrehg.
There are two main parts to achieving this:
- Download Balena device image (Intel NUC) and optionally pre-load it with an existing app
- Build a virtual machine image based on that image
Download an Intel-NUC based Balena device image
- Create an app if you haven’t already on https://dashboard.balena-cloud.com/
- Download the production version of the image (about 600mb)
Install a very specific version of Docker that still supports AUFS
Open the Docker Desktop settings panel and tick the checkbox
Expose daemon on tcp://localhost:2375 without TLS. Also go to the Shared Drives settings and be sure to share the C drive else you’ll get adrive not sharederror when runningbalena preload.
Pre-load the Balena image with your app (optional)
- Install the Balena cli: https://github.com/balena-io/balena-cli
Docker must be running properly for the next step to work.
- Run
Convert the .IMG file to .VMDK
The image needs to be mounted in the virtual machine, similar to plugging in a USB drive, however you can’t mount the .img file directly. Unfortunately VMware doesn’t have a utility for this (please comment if so) but VirtualBox does.
It must be converted to a .vmdk (virtual disk) using the VBoxManage convertdd command.
- Run
VBoxManage convertdd <img name>.img <img name>.vmdk --format VMDK
Create a VMware virtual machine image
You have to modify the VMDK file type from 5 (streamOptimized) to 2 (monolithicFlat). It doesn’t matter here, but types 0, 1, and 3 would also work. This is not needed for VirtualBox.
- Run
vmware-vdiskmanager -r <source>.vmdk -t 2 <target>.vmdk
This creates a -flat.vmdk file that’s 4x the size of the original. Note: We’re going to attach the 1kb .vmdk file that references that -flat file, not the -flat file itself.
Open VMware Workstation (you’ll need a license or trial version) and create a new Virtual Machine. Use Custom (advanced) otherwise you won’t get the option to specify disk controller type or select an existing disk.
- Install the operating system later
- Linux / Debian 6 (64-bit)
- Name Tend Cellmate (Customer)
- 4GB Disk, store virtual disk as a single file
- Use default settings until you get to
Select a Disk Type- choose SATA as SCSI doesn’t support AHCI and it will not boot properly. - At
Select a Disk- choose ‘Use an existing virtual disk’ - Choose the 1kb VMDK file (non-flat) that was created earlier. It may prompt to convert it to the latest version - go ahead, it doesn’t matter unless you plan on using it in previous versions of VMWare.
Click finish, then edit the virtual machine settings. You need to add a Click Add on the Hardware tab and select Hard Disk.
- Choose SATA > Create a new virtual disk
- 4 GB, Store virtual disk as a single file
Note: It is critical that the original Balena VMDK is set to SATA 0:0 otherwise it will not boot properly. It should be already configured as such, but you can click the Advanced button to double check.
Skip the next section.
Create a VirtualBox virtual machine image
- Open VirtualBox and create a new Virtual Machine
- Name: Virtual Cellmate (customer name)
- Type: Linux
- Version: Debian (64-bit)
- Memory: at least 2GB
- Hard disk: Create a virtual hard disk:
- VDI
- Dynamically allocated
- 4GB in size
You should now have a virtual machine created. Edit the settings:
- System:
- Uncheck
Enable I/O APIC(will not boot otherwise) - Check
Enable EFI
- Uncheck
- Storage:
- You will see the virtual disk you created earlier under
Controller: SATA - Click
Controller: SATAand add a new hard disk - Choose existing disk
- Click Add (you will end up with 2 different disks attached)
- Select the pre-loaded .vmdk file that was created earlier - this is the disk that the virtual machine will boot from and flash the other disk with the Balena image
- Click Choose and you should now see the two disks attached to
Controller: SATA
- Network:
- This should default to
NATwhich is what you want
Provision the virtual machine with the Balena image
Now you should have the original VMDK attached for boot and a new virtual disk to provision with the Balena image. Start the virtual machine and open up the Balena dashboard to see it come online (https://dashboard.balena-cloud.com) Once it appears, you should name it something meaningful.
The device will enter a Post-Provisioning state. Do not interrupt this process - it will take a few minutes and the virtual machine will power off. Be sure to let it power off on it’s own. If it does not turn off, or if you accidentally turn it off, delete the device from Balena and start the virtual machine again - it should provision a new device.
Important: Once it is powered off, go to the virtual machine settings and remove the Balena VMDK disk, otherwise you will re-flash a new image every time you boot. This is the equivalent of removing the USB stick from the device. You should only have one virtual disk attached to Controller: SATA.
At this point you have a virtual machine image that is the equivalent of a physical device. Now the image can be packaged as a virtual appliance so that it can be easily distributed (and users can just double click on and load into VirtualBox or VMware).
Create a virtual appliance from a Balena image
Open VirtualBox or VMware (the process is the same):
- Click
File > Export - Be sure to create an .ova file, as this combines everything into a single file. An .ovf file will separate out the .vmdk so would require a .zip file to redistribute easily.
Click Export and that’s it!
One thing to note: If you send this appliance to 10 people, there will still only be 1 device in Balena, so you may want to create 10 separate appliances instead, which then provision 10 separate devices in Balena.
