How to check which JetPack version I am using on Balena ?
Hi, I installed BalenaOS into a Jetson Xavier device and I have a Jetson Xavier container pushed to the fleet.
I want to install tensorRT, cuda etc but I can’t figure out whether or not I have a Nvidia JetPack installed and which version it is
Where can see that information from the balena OS, container, image or even docker hub ?
I just want know exactly what I have installed
The best way is to check at source (search for L4T): balena-jetson/CHANGELOG.md at master · balena-os/balena-jetson · GitHub
Another good solution, if you have a running device, is to run: uname -a it will tell you which L4T it’s running on.
