How implement environment variables?
Hello community
i was watching this helpful video to setup openBalena
And works properly without any problem.
After this i deployed with " balena deploy testApp --emulated --logs --build"
this git repo https://github.com/jpmeijers/ttn-resin-gateway-rpi to the openBalena Server
But i have no idea how can set this enviroment variable.
|GW_ID|The gateway ID from the TTN console|
|GW_KEY|The gateway KEY from the TTN console|
|GW_RESET_PIN|22 (optional)|
Can anyone help me to implement the environment variable ?
Best regards Joachim
Hey,
One could setup env var using the dashboard and here is a relevant doc:
https://www.balena.io/docs/learn/manage/serv-vars/
or directly from the CLI (remove/add/list):
https://www.balena.io/docs/reference/cli/#envs
See the CLI doc, as it allows you to quickly verify the variables configuration on your local device.
hth
Thank you very much for your help.
Problem solved.
Regards Joachim
