I am trying to set up some variables through a shell script and I have noticed that it appears impossible to set a variable with a double- or single-quote inside.
For example, one would expect the following to work:
@floion - thanks, that is what can be used most of the time.
However, we have a couple of different dtoverlay settings that are for different modules and need to be on their own separate lines. This is done fine if set through the balenaCloud UI, but not when set from the balena-cli.
I wanted to follow up and see if you’ve had a chance to test balena-cli>=11.18.0? If so, can you provide a minimal example of what is still not working?
