Hi @fintanusa welcome to the forums! Do you see the same behaviour when flashing a different linux distribution, for example ubuntu? Can you try with a different USB stick and see if you have a different result
HI and thank you for that. I had already successsfuly flashed Kubunutu and debian based netrunner in the past and did it again today. So, that works. Does Etcher have issues with arch based distros? I also tried contacting on the Manjero and netrunner forums but no reaction at all for 4 weeks. Mmmmm…
As my colleague has said, if it works with dd (or another flashing application) it should definitely work with Etcher. Have you tried any other distributions or versions?
grub is a bootloader which is used to boot Linux for these distributions, and it sounds like there may be an issue with the written distributions.
