Grafana sms notification using webhooks and AWS
Hi
I am trying to build an SMS notification service to use with grafana to send sms alerts.
It is based of this article SMS Alerts in Grafana using a Custom Webhook and AWS SNS | Medium.
The configuration I used : https://github.com/ausyp/Balena_sms
I was able to spin up the container and get it working.
When trying to setup notification on grafana the test is failing.
I have tried using localhost but no use.
As way to test the python script used (not.py) I tried running the script in the same container as grafana on port 5000 and the notification sms is succesfull. So the script must be okay.
this is my docker-compse
version: '2'
volumes:
    sense-data:
services:
  influxdb:
    restart: always
    build: ./influxdb
    volumes:
      - 'sense-data:/data'
  grafana:
    restart: always
    build: ./grafana
    ports:
      - "80"
    volumes:
    environment:
        - 'HOME_DASHBOARD_UID=balenaSense'
        - 'GF_PATHS_DATA=/data/grafana'
        - 'GF_SERVER_HTTP_PORT=80'
        - 'GF_SESSION_PROVIDER=memory'
        - 'GF_AUTH_ANONYMOUS_ENABLED=true'
  sensor:
    build: ./sensor
    privileged: true
    restart: always
    volumes:
  sms:
    build: ./sms
    restart: always
Does anyone have any suggession or ideas what I might be doing wrong ?
Any help appriciated.
Never mind Figured it out. use
  sms:
    build: ./sms
    restart: always
    hostname: sms
Super cool project @Ausyp
Tell us more on the Show & Tell category why are you using Grafana + SMS alerts on your IoT Edge project.
Looking forward to learn more about it.
So I am building temperature monitoring device for vaccine fridges. The main Idea being to be able to intervene before a temperature breach and prevent vaccine wastage. Thats why SMS notification is needed.
Hello @Ausyp did you solve your issues on your project?
Hey! is everything running good now?
I have been away for a while. Everything is going good thanks for checking. thanks for all your help. :slight_smile:
Good to hear that the wproject works now @Ausyp
Let us know how more we can help you!
