DEBUG: Executing shell function do_compile
#1 [internal] load .dockerignore
#1 transferring context: 2B done
#1 DONE 0.0s
#2 [internal] load build definition from Dockerfile
#2 transferring dockerfile: 219B done
#2 DONE 0.0s
#3 [internal] load metadata for Docker Hub Container Image Library | App Containerization
#3 ERROR: failed to authorize: failed to fetch anonymous token: Get “https://auth.docker.io/token?scope=repository%3Alibrary%2Fdebian%3Apull&service=registry.docker.io”: dial tcp: lookup auth.docker.io on 127.0.0.53:53: dial udp 127.0.0.53:53: connect: network is unreachable
Dockerfile:1
1 | >>> FROM debian:stretch
2 |
3 | VOLUME /mnt/sysroot/inactive
ERROR: failed to solve: failed to fetch anonymous token: Get “https://auth.docker.io/token?scope=repository%3Alibrary%2Fdebian%3Apull&service=registry.docker.io”: dial tcp: lookup auth.docker.io on 127.0.0.53:53: dial udp 127.0.0.53:53: connect: network is unreachable
Error response from daemon: invalid reference format
WARNING: /home/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/temp/run.do_compile.37732:153 exit 1 from ‘DOCKER_API_VERSION=1.22 docker save “$IMAGE_ID” > /home/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/work/mkfs-hostapp-image.tar’
WARNING: Backtrace (BB generated script):
#1: do_compile, /home/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/temp/run.do_compile.37732, line 153
#2: main, /home/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/temp/run.do_compile.37732, line 160
