I’m new to Balena and currently trying to get BalenaOS running in a Docker container (Docker for Windows) using the balenaos-in-container git repo.
When I run docker-compose up --build the image builds, and the container starts but then exits with the following errors:
Configuration file /etc/systemd/system.conf.d/watchdog.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
Failed to create symlink /sys/fs/cgroup/net_cls: File exists
Failed to create symlink /sys/fs/cgroup/net_prio: File exists
Failed to create symlink /sys/fs/cgroup/cpu: File exists
Failed to create symlink /sys/fs/cgroup/cpuacct: File existsWelcome to balenaOS 2.83.18+rev1!
Failed to attach 1 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/init.scope: No such file or directory
/lib/systemd/system/balena-host.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/balena-host.sock → /run/balena-host.sock; please update the unit file accordingly.
/lib/systemd/system/balena-engine.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/balena-engine.sock → /run/balena-engine.sock; please update the unit file accordingly.
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-resin\x2dinfo.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target Slices.
[ OK ] Reached target Swap.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
Failed to attach 21 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/dev-hugepages.mount: No such file or directory
Mounting Huge Pages File System…
Failed to attach 22 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/sys-kernel-debug.mount: No such file or directory
Mounting Kernel Debug File System…
Failed to attach 23 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/mnt-sysroot-active.service: No such file or directory
Starting Resin active root partition mount service…
Failed to attach 24 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/resin-boot.service: No such file or directory
Starting Resin boot partition mount service…
Failed to attach 25 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/resin-state.service: No such file or directory
Starting Resin state partition mount service…
Failed to attach 27 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/rollback-clear-bootcount.service: No such file or directory
Starting Rollback clear bo…boot crumb is still present…
Failed to attach 29 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/sys-fs-fuse-connections.mount: No such file or directory
Mounting FUSE Control File System…
Failed to attach 31 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-remount-fs.service: No such file or directory
Starting Remount Root and Kernel File Systems…
Failed to attach 32 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-sysctl.service: No such file or directory
Starting Apply Kernel Variables…
Failed to attach 33 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-udev-settle.service: No such file or directory
Starting udev Wait for Complete Device Initialization…
Failed to attach 38 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-vconsole-setup.service: No such file or directory
Starting Setup Virtual Console…
Failed to attach 39 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/timeinit-buildtime.service: No such file or directory
Starting Set the system clock from the build timestamp…
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted Kernel Debug File System.
resin-boot.service: Main process exited, code=exited, status=1/FAILURE
resin-boot.service: Failed with result ‘exit-code’.
[FAILED] Failed to start Resin boot partition mount service.
See ‘systemctl status resin-boot.service’ for details.
[DEPEND] Dependency failed for reds… transparent proxy redirector.
redsocks.service: Job redsocks.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for OS configuration update service.
os-config.service: Job os-config.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Resin proxy configuration service.
balena-proxy-config.service: Job balena-proxy-config.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Balena rollback checks health.
rollback-health.service: Job rollback-health.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for OS c…figuration device key service.
[DEPEND] Dependency failed for Prepare OpenVPN.
[DEPEND] Dependency failed for OpenVPN.
openvpn.service: Job openvpn.service/start failed with result ‘dependency’.
prepare-openvpn.service: Job prepare-openvpn.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Balena supervisor.
balena-supervisor.service: Job balena-supervisor.service/start failed with result ‘dependency’.
os-config-devicekey.service: Job os-config-devicekey.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for udev…onfiguration from config.json.
os-udevrules.service: Job os-udevrules.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Config.json path watch.
config-json.path: Job config-json.path/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Resin network configure service.
[DEPEND] Dependency failed for Resin NTP server configure service.
balena-ntp-config.service: Job balena-ntp-config.service/start failed with result ‘dependency’.
balena-net-config.service: Job balena-net-config.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Balena device UUID.
[DEPEND] Dependency failed for Balena Hostname Configuration.
[DEPEND] Dependency failed for Avahi mDNS/DNS-SD Stack.
avahi-daemon.service: Job avahi-daemon.service/start failed with result ‘dependency’.
balena-hostname.service: Job balena-hostname.service/start failed with result ‘dependency’.
balena-device-uuid.service: Job balena-device-uuid.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Netw…on fragments from config.json.
os-networkmanager.service: Job os-networkmanager.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Resin persistent logs.
resin-persistent-logs.service: Job resin-persistent-logs.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for OS SSH keys.
os-sshkeys.service: Job os-sshkeys.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Balena rollback checks altboot.
rollback-altboot.service: Job rollback-altboot.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Show Plymouth Boot Screen.
plymouth-start.service: Job plymouth-start.service/start failed with result ‘dependency’.
resin-state.service: Main process exited, code=exited, status=1/FAILURE
resin-state.service: Failed with result ‘exit-code’.
[FAILED] Failed to start Resin state partition mount service.
See ‘systemctl status resin-state.service’ for details.
[DEPEND] Dependency failed for Bind…orkManager/system-connections.
bind-etc-NetworkManager-system-connections.service: Job bind-etc-NetworkManager-system-connections.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /var/lib/chrony.
bind-var-lib-chrony.service: Job bind-var-lib-chrony.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/fake-hwclock.
[DEPEND] Dependency failed for Restore/save the current clock.
fake-hwclock.service: Job fake-hwclock.service/start failed with result ‘dependency’.
etc-fake\x2dhwclock.mount: Job etc-fake\x2dhwclock.mount/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /home/root/.ssh.
bind-home-root-.ssh.service: Job bind-home-root-.ssh.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /home/root/.rnd.
bind-home-root-.rnd.service: Job bind-home-root-.rnd.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /var/lib/systemd.
bind-var-lib-systemd.service: Job bind-var-lib-systemd.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /home/root/.docker.
[DEPEND] Dependency failed for Bale… Application Container Engine.
balena.service: Job balena.service/start failed with result ‘dependency’.
bind-home-root-.docker.service: Job bind-home-root-.docker.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind…t for /var/lib/NetworkManager.
bind-var-lib-NetworkManager.service: Job bind-var-lib-NetworkManager.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/udev/rules.d.
bind-etc-udev-rules.d.service: Job bind-etc-udev-rules.d.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/openvpn.
bind-etc-openvpn.service: Job bind-etc-openvpn.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind…nt for /etc/balena-supervisor.
bind-etc-balena-supervisor.service: Job bind-etc-balena-supervisor.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/hostname.
bind-etc-hostname.service: Job bind-etc-hostname.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/ssl/certs.
bind-etc-ssl-certs.service: Job bind-etc-ssl-certs.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind…or /etc/NetworkManager/conf.d.
bind-etc-NetworkManager-conf.d.service: Job bind-etc-NetworkManager-conf.d.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/docker.
bind-etc-docker.service: Job bind-etc-docker.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for OpenSSH Key Generation.
sshdgenkeys.service: Job sshdgenkeys.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind…/share/ca-certificates/balena.
[DEPEND] Dependency failed for Extract custom CA from config.json.
extract-balena-ca.service: Job extract-balena-ca.service/start failed with result ‘dependency’.
bind-usr-share-ca-certificates-balena.service: Job bind-usr-share-ca-certificates-balena.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Resin reset OS state.
[DEPEND] Dependency failed for Bind mount for /var/lib/bluetooth.
bind-var-lib-bluetooth.service: Job bind-var-lib-bluetooth.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Bind mount for /etc/ssh/hostkeys.
bind-etc-ssh-hostkeys.service: Job bind-etc-ssh-hostkeys.service/start failed with result ‘dependency’.
resin-state-reset.service: Job resin-state-reset.service/start failed with result ‘dependency’.
[DEPEND] Dependency failed for Balena supervisor state migrator.
migrate-supervisor-state.service: Job migrate-supervisor-state.service/start failed with result ‘dependency’.
[ OK ] Started Rollback clear boo…ltboot crumb is still present.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Set the system clock from the build timestamp.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Paths.
Failed to attach 44 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/resin-filesystem-expand.service: No such file or directory
Starting Expand resin-data partition…
Failed to attach 45 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-journald.service: No such file or directory
Starting Journal Service…
Failed to attach 48 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-tmpfiles-setup-dev.service: No such file or directory
Starting Create Static Device Nodes in /dev…
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Set up automount mnt-sysroot-inactive partition.
Failed to attach 50 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/var-volatile.mount: No such file or directory
Mounting /var/volatile…
Failed to attach 51 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-udevd.service: No such file or directory
Starting udev Kernel Device Manager…
[ OK ] Mounted /var/volatile.
Failed to attach 52 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/var-volatile-cache.service: No such file or directory
Starting Bind mount volatile /var/cache…
Failed to attach 53 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/var-volatile-lib.service: No such file or directory
Starting Bind mount volatile /var/lib…
Failed to attach 54 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/var-volatile-spool.service: No such file or directory
Starting Bind mount volatile /var/spool…
Failed to attach 56 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/var-volatile-srv.service: No such file or directory
Starting Bind mount volatile /srv…
[ OK ] Started Bind mount volatile /var/cache.
[ OK ] Started Bind mount volatile /var/lib.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Bind mount volatile /var/spool.
[ OK ] Started Bind mount volatile /srv.
Failed to attach 76 to compat systemd cgroup /docker/ae0468932f87a176d281aabc15bdc71974383d72a2d6fe69ee734b074977ea37/system.slice/systemd-journald.service: No such file or directory
[ OK ] Started Journal Service.
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Time Set.
[* ] (1 of 3) A start job is running for…tion mount service (5s / no limit)[** ] (1 of 3) A start job is running for…tion mount service (5s / no limit)
[*** ] (1 of 3) A start job is running for…tion mount service (6s / no limit)
[ *** ] (2 of 3) A start job is running for…sin-data partition (6s / no limit)
[ *** ] (2 of 3) A start job is running for…sin-data partition (7s / no limit)
[ ***] (2 of 3) A start job is running for…sin-data partition (7s / no limit)
[ **] (3 of 3) A start job is running for /dev/zram0 (8s / 1min 30s)
[ *] (3 of 3) A start job is running for /dev/zram0 (8s / 1min 30s)
[ **] (3 of 3) A start job is running for /dev/zram0 (9s / 1min 30s)
[ ***] (1 of 3) A start job is running for…tion mount service (9s / no limit)
[ *** ] (1 of 3) A start job is running for…ion mount service (10s / no limit)
[*** ] (2 of 3) A start job is running for…in-data partition (11s / no limit)
[** ] (2 of 3) A start job is running for…in-data partition (11s / no limit)
[* ] (2 of 3) A start job is running for…in-data partition (12s / no limit)
[** ] (3 of 3) A start job is running for /dev/zram0 (12s / 1min 30s)
[*** ] (3 of 3) A start job is running for /dev/zram0 (13s / 1min 30s)
[ *** ] (3 of 3) A start job is running for /dev/zram0 (13s / 1min 30s)
[ *** ] (1 of 3) A start job is running for…ion mount service (14s / no limit)
[ ***] (1 of 3) A start job is running for…ion mount service (14s / no limit)
[ **] (1 of 3) A start job is running for…ion mount service (15s / no limit)
[ *] (2 of 3) A start job is running for…in-data partition (15s / no limit)
[ **] (2 of 3) A start job is running for…in-data partition (16s / no limit)
[ ***] (2 of 3) A start job is running for…in-data partition (16s / no limit)
[ *** ] (3 of 3) A start job is running for /dev/zram0 (17s / 1min 30s)
[*** ] (3 of 3) A start job is running for /dev/zram0 (18s / 1min 30s)
[** ] (1 of 3) A start job is running for…ion mount service (18s / no limit)
[* ] (1 of 3) A start job is running for…ion mount service (19s / no limit)
[** ] (1 of 3) A start job is running for…ion mount service (19s / no limit)
[*** ] (2 of 3) A start job is running for…in-data partition (20s / no limit)
[ *** ] (2 of 3) A start job is running for…in-data partition (20s / no limit)
[ *** ] (2 of 3) A start job is running for…in-data partition (21s / no limit)
[ ***] (3 of 3) A start job is running for /dev/zram0 (21s / 1min 30s)
[ **] (3 of 3) A start job is running for /dev/zram0 (22s / 1min 30s)
[ *] (3 of 3) A start job is running for /dev/zram0 (22s / 1min 30s)
[ **] (1 of 3) A start job is running for…ion mount service (23s / no limit)
[ ***] (1 of 3) A start job is running for…ion mount service (23s / no limit)
[ *** ] (1 of 3) A start job is running for…ion mount service (24s / no limit)
[ *** ] (2 of 3) A start job is running for…in-data partition (24s / no limit)
[*** ] (2 of 3) A start job is running for…in-data partition (25s / no limit)
[** ] (2 of 3) A start job is running for…in-data partition (25s / no limit)
[* ] (3 of 3) A start job is running for /dev/zram0 (26s / 1min 30s)
[** ] (3 of 3) A start job is running for /dev/zram0 (26s / 1min 30s)
[*** ] (3 of 3) A start job is running for /dev/zram0 (27s / 1min 30s)
[ *** ] (1 of 3) A start job is running for…ion mount service (27s / no limit)
[ *** ] (1 of 3) A start job is running for…ion mount service (28s / no limit)
[ ***] (1 of 3) A start job is running for…ion mount service (28s / no limit)
[ **] (2 of 3) A start job is running for…in-data partition (29s / no limit)
[ *] (2 of 3) A start job is running for…in-data partition (29s / no limit)
[FAILED] Failed to start Resin acti… root partition mount service.
See ‘systemctl status mnt-sysroot-active.service’ for details.
The host machine is running Windows 10 with the latest version of Docker Desktop and WSL2 with Ubuntu installed as the default WSL2 distro.
Any ideas?
Thanks.
