I have cloned the repository:
git clone --recursive https://github.com/balena-os/balena-raspberrypi.git
And started the build:
./balena-yocto-scripts/build/barys -m "raspberrypi4-64"
I get the following error from the mkfs-hostapp-native recipe:
Initialising tasks: 100% |########################################################################################################################################################################| Time: 0:00:02
Sstate summary: Wanted 33 Local 2 Mirrors 0 Missed 31 Current 1863 (6% match, 98% complete)
NOTE: Executing Tasks
ERROR: mkfs-hostapp-native-1.0-r0 do_compile: ExecutionError('/home/ben.s/yocto/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/temp/run.do_compile.185525', 1, None, None)
ERROR: Logfile of failure stored in: /home/ben.s/yocto/balena-raspberrypi/build/tmp/work/x86_64-linux/mkfs-hostapp-native/1.0-r0/temp/log.do_compile.185525
Log data follows:
| DEBUG: Executing shell function do_compile
| #1 [internal] load .dockerignore
| #1 transferring context: 2B done
| #1 DONE 0.0s
| #2 [internal] load build definition from Dockerfile
| #2 transferring dockerfile: 219B done
| #2 DONE 0.0s
| #3 [internal] load metadata for docker.io/library/debian:stretch
| #3 DONE 1.0s
| #4 [1/3] FROM docker.io/library/debian:stretch@sha256:c5c5200ff1e9c73ffbf188b4a67eb1c91531b644856b4aefe86a58d2f0cb05be
| #4 DONE 0.0s
| #5 [internal] load build context
| #5 transferring context: 334B done
| #5 DONE 0.0s
| #6 [2/3] RUN apt-get update && apt-get install -y ca-certificates iptables
| #6 CACHED
| #7 [3/3] COPY create.* /usr/bin/
| #7 CACHED
| #8 exporting to image
| #8 exporting layers done
| #8 writing image sha256:2bc0a7bcf745aa7803ff0e9217b5a49372770fd80470802682f65f9fe8afff81 done
| #8 DONE 0.0s
| Error response from daemon: invalid reference format
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/ben.s/yocto/balena-raspberrypi/build/../layers/meta-balena/meta-balena-common/recipes-containers/mkfs-hostapp-native/mkfs-hostapp-native.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 4445 tasks of which 4443 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message, returning a non-zero exit code.
[000000038][LOG]Build for raspberrypi4-64 failed. Check failed log in build/tmp/log/cooker/raspberrypi4-64 .
[000000039][LOG]If build for raspberrypi4-64 succeeded, final image should have been generated here:
[000000039][LOG] build/tmp/deploy/images/raspberrypi4-64/balena-image-raspberrypi4-64.balenaos-img
[000000039][LOG]Done.
I have debugged this issue and see that this line is the problem in recipe mkfs-hostapp-native.bb:
IMAGE_ID=$(DOCKER_API_VERSION=1.22 docker build ${B}/work | grep -o -E '[a-z0-9]{12}' | tail -n1)
Here IMAGE_ID remains empty and is not set correctly, even though the docker build command works correctly. I think it is because the docker build output is to stderr and not stdout.
I tried to redirect the output but encountered further errors.
My system:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
My docker:
Docker version 23.0.0, build e92dd87
