Summary: 1 task failed:
/home/balena-raspberrypi/build/…/layers/meta-balena/meta-balena-common/recipes-containers/mkfs-hostapp-native/mkfs-hostapp-native.bb:do_compile
Summary: There was 1 ERROR message, returning a non-zero exit code.
[000009490][LOG]Build for rt-rpi-300 failed. Check failed log in build/tmp/log/cooker/rt-rpi-300 .
[000009490][LOG]If build for fincm3 succeeded, final image should have been generated here:
[000009490][LOG] build/tmp/deploy/images/fincm3/balena-image-fincm3.balenaos-img
[000009491][LOG]If build for npe-x500-m3 succeeded, final image should have been generated here:
[000009491][LOG] build/tmp/deploy/images/npe-x500-m3/balena-image-npe-x500-m3.balenaos-img
[000009492][LOG]If build for raspberrypi0-2w-64 succeeded, final image should have been generated here:
[000009492][LOG] build/tmp/deploy/images/raspberrypi0-2w-64/balena-image-raspberrypi0-2w-64.balenaos-img
[000009492][LOG]If build for raspberrypi2 succeeded, final image should have been generated here:
[000009492][LOG] build/tmp/deploy/images/raspberrypi2/balena-image-raspberrypi2.balenaos-img
[000009493][LOG]If build for raspberrypi3-64 succeeded, final image should have been generated here:
[000009493][LOG] build/tmp/deploy/images/raspberrypi3-64/balena-image-raspberrypi3-64.balenaos-img
[000009493][LOG]If build for raspberrypi3 succeeded, final image should have been generated here:
[000009493][LOG] build/tmp/deploy/images/raspberrypi3/balena-image-raspberrypi3.balenaos-img
[000009494][LOG]If build for raspberrypi3-unipi-neuron succeeded, final image should have been generated here:
[000009494][LOG] build/tmp/deploy/images/raspberrypi3-unipi-neuron/balena-image-raspberrypi3-unipi-neuron.balenaos-img
[000009494][LOG]If build for raspberrypi400-64 succeeded, final image should have been generated here:
[000009494][LOG] build/tmp/deploy/images/raspberrypi400-64/balena-image-raspberrypi400-64.balenaos-img
[000009495][LOG]If build for raspberrypi4-64 succeeded, final image should have been generated here:
[000009495][LOG] build/tmp/deploy/images/raspberrypi4-64/balena-image-raspberrypi4-64.balenaos-img
[000009495][LOG]If build for raspberrypi4-unipi-neuron succeeded, final image should have been generated here:
[000009495][LOG] build/tmp/deploy/images/raspberrypi4-unipi-neuron/balena-image-raspberrypi4-unipi-neuron.balenaos-img
[000009496][LOG]If build for raspberrypicm4-ioboard succeeded, final image should have been generated here:
[000009496][LOG] build/tmp/deploy/images/raspberrypicm4-ioboard/balena-image-raspberrypicm4-ioboard.balenaos-img
[000009497][LOG]If build for raspberrypi succeeded, final image should have been generated here:
[000009497][LOG] build/tmp/deploy/images/raspberrypi/balena-image-raspberrypi.balenaos-img
[000009497][LOG]If build for revpi-connect succeeded, final image should have been generated here:
[000009497][LOG] build/tmp/deploy/images/revpi-connect/balena-image-revpi-connect.balenaos-img
[000009498][LOG]If build for revpi-core-3 succeeded, final image should have been generated here:
[000009498][LOG] build/tmp/deploy/images/revpi-core-3/balena-image-revpi-core-3.balenaos-img
[000009498][LOG]If build for rt-rpi-300 succeeded, final image should have been generated here:
[000009498][LOG] build/tmp/deploy/images/rt-rpi-300/balena-image-rt-rpi-300.balenaos-img
[000009498][LOG]Done.
