Get chromium remote dev tools running on Balena Dash
Hello, I am trying to debug my slow chromium on a Fin, I am trying to follow this tutorial
https://blog.sebastian-martens.de/development/raspberry-pi-remote-debug-chrome/
I am not sure why it is not working but I have added --remote-debugging-port=9222 --incognito onto the chromium-browser command as well as added the
   ports:
      - 8080:8080
      - 80:9222
When I open the device public url I get the following
We encountered an error when reaching this balena.io device:
UUID 3126d7f8b1d20839faa1dd8476696b41
tunneling socket could not be established: 500
One possible reason is because nothing is listening on port 80 on the device
Why can I access it?
Do you have the logs from the device ?
Are you sure chromium is listening on port 9222 in the container ?
You can check with netstat -ltn in the container.
If you’re on the same network as the device, you can try to directly open http://<device-ip> in a browser.
Thanks @zvin,
I get the following after setting
   ports:
      - 8080:8080
      - 9222:9222
the ports
root@3126d7f:~# netstat -ltn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 127.0.0.2:53            0.0.0.0:*               LISTEN
tcp        0      0 10.114.102.1:53         0.0.0.0:*               LISTEN
tcp        0      0 :::48484                :::*                    LISTEN
tcp        0      0 :::9222                 :::*                    LISTEN
tcp        0      0 :::2375                 :::*                    LISTEN
tcp        0      0 :::22222                :::*                    LISTEN
tcp        0      0 :::8080                 :::*                    LISTEN
However if I scan for my device, and get the IP: 192.168.0.38, and try visit it, or 192.168.0.38:9222, I just get
This site can’t be reached
Ive also tried --headless --no-sandbox too
and EXPOSE 9222
Any ideas why this is not working?
Can you connect toper 9222 from within the device? If that works, then we know there is something wrong with how that port is getting exposed, and dig further on that. Otherwise, it’d indicate a problem in how Chrome is being ran
Yes I can,
In the host OS, I can ping it
root@3126d7f:~# ping 0.0.0.0:9222
PING 0.0.0.0:9222 (0.0.0.0): 56 data bytes
64 bytes from 127.0.0.1: seq=0 ttl=64 time=0.321 ms
64 bytes from 127.0.0.1: seq=1 ttl=64 time=0.247 ms
64 bytes from 127.0.0.1: seq=2 ttl=64 time=0.258 ms
64 bytes from 127.0.0.1: seq=3 ttl=64 time=0.274 ms
Hey Patrick,
Is there a chance you can share the app code with us, so we can inspect it and see if there is something going on? I’m particularly interested in the container than runs Chrome, and the docker-compose.yml definition
Hello, you can’t ping a port.
To check if it works you’d need to run telnet 0.0.0.0 9222.
I guess it works as it listens on :::9222. (I don’t know why it doesn’t listen on 127.0.0.1:9222 though).
You should see in chromium logs something like
DevTools listening on ws://127.0.0.1:9222/devtools/browser/xxxxxxxxxxxxxxxxxx
Anyway, it turns out --remote-debugging-port only listens on the loopback interface so it won’t be reachable from another computer.
You’ll need to run an http proxy on 0.0.0.0:9222 redirecting to 127.0.0.1:9222, tinyproxy or anything similar.
For reference: https://stackoverflow.com/questions/40538197/chrome-remote-debugging-from-another-machine
Even simpler than tinyproxy: simpleproxy -L <device ip address>:9222 -R 127.0.0.1:9222
And even simpler: listen on another port:
simpleproxy -L 9223 -R 127.0.0.1:9222
In your compose file use 80:9223
I am getting this reponse from telnet
telnet 0.0.0.0 9222
Connection closed by foreign host
When I run it in the host os or in my service
Here is my docker compose
version: "2"
volumes:
  settings:
  cookies:
  cups:
services:
  kiosk:
    restart: always
    build: ./kiosk
    labels:
      io.balena.features.kernel-modules: "1"
      io.balena.features.firmware: "1"
      io.balena.features.dbus: "1"
      io.balena.features.supervisor-api: "1"
      io.balena.features.balena-api: "1"
    privileged: true
    environment:
      - DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
    ports:
      - 8080:8080
      - 80:9223
    volumes:
      - "settings:/usr/src/app/settings"
After making your changes
And my docker.fincm3
# build tohora from source
FROM balenalib/raspberrypi3-golang as builder
RUN go get -d -v github.com/mozz100/tohora/...
WORKDIR /go/src/github.com/mozz100/tohora
RUN go build
# use smaller image
FROM balenalib/rpi-raspbian
RUN install_packages wget \
    xserver-xorg-video-fbdev \
    xserver-xorg xinit \
    xterm x11-xserver-utils \
    xterm \
    dbus-x11 \
    dbus \
    xserver-xorg-input-evdev \
    xserver-xorg-legacy \
    mesa-vdpau-drivers \
    chromium-browser \
    rpi-chromium-mods \
    libgles2-mesa \
    lsb-release \
    cec-utils
# Setting working directory
WORKDIR /usr/src/app
COPY start.sh ./
ENV LAUNCH_URL http://pos-demo.entabeni.tech/
ENV UDEV=1
ENV FLAGS $KIOSK --remote-debugging-port=9222 --headless --no-sandbox --incognito --disable-dev-shm-usage --ignore-gpu-blacklist --enable-gpu-rasterization --force-gpu-rasterization --autoplay-policy=no-user-gesture-required --user-data-dir=/usr/src/app/settings --enable-features=WebRTC-H264WithOpenH264FFmpeg --window-position=0,0
EXPOSE 9222
# Add chromium user
RUN useradd chromium -m -s /bin/bash -G root && \
    groupadd -r -f chromium && id -u chromium \
    && chown -R chromium:chromium /home/chromium
# udev rule to set specific permissions
RUN echo 'SUBSYSTEM=="vchiq",GROUP="video",MODE="0660"' > /etc/udev/rules.d/10-vchiq-permissions.rules
RUN usermod -a -G audio,video,tty chromium
COPY public_html /home/chromium/public_html
COPY --from=builder /go/src/github.com/mozz100/tohora /home/chromium/tohora
COPY launch.sh /home/chromium/
CMD ["bash", "start.sh"]
What happens if you run it from the container running chromium ?
Sorry, In my service, means, in the chromium container
Hi Patrick,
Last night I tried to get my Fin into a representative state to test this for you, using your site (and some test login details that Daniel gave me) and a TV with the same resolution you are using. Initially I could see that there was lag, especially when opening the site initially. I used the Chromium menu’s to open task manager, and saw that the GPU process was maxing out the CPU. I believe that’s because the options --enable-gpu-rasterization --force-gpu-rasterization are causing the screen to render on the GPU, but hardware acceleration isn’t enabled (or enabled but not working) for the CM3. This results in a high CPU load. To test this theory I disabled those flags and ran the site again, and found it to be much more performant. There was still some lag, but this is quite a large screen to be driven by a Cortex-A53 CPU with only 1Gb of memory - and I found the site to be very usable.
For now I think the next thing to try (before we continue trying to get Chromium DevTools working) is to use the site with the GPU disabled. You can do this by setting the following in an environment variable on the KIOSK service, set FLAGS to --disable-dev-shm-usage --user-data-dir=/usr/src/app/settings --window-position=0,0 which effectively removes the flags trying to enable the GPU use.
For context: the GPU flags are there to try and make running YouTube videos and WebGL content performant. For displaying web content on balenaDash which does not have video or WebGL, they are not needed and seem to cause higher CPU load.
Please let me know how this testing goes, and I’ll leave my Fin set up for your application in case I can help further.
Phil
Thanks a lot @phil-d-wilson ,
There is a noticeable improvement when I do that. Does that mean that you can set Define device GPU memory in megabytes to 0?
Patrick,
Good question…let me try and get back to you.
Phil
Hi Patrick,
You can set the value to zero, but I believe the minimum is actually 16, which the OS will default to. I’ve just run your site again, and it worked fine with this setting. I didn’t notice any improvement, but it makes sense to minimise the amount of memory allocated to the GPU in your case.
Phil
Thanks @phil-d-wilson,
Its working a lot better now
You’re very welcome!
I’ll close this support thread (as long as you are happy) but keep looking into the Chrome DevTools in case you do need them, and because it will potentially benefit others. If you have any more questions or issues, you can still reply here and the thread will re-open.
Phil
