Hi there, the data should persist between reboots, since it is mapped to a named volume. As long as that volume name does not change, the data in the volume will persist across updates. Have you checked the contents of /data in your containers?
Hey @maigonis, we are using influxdb to store the data on the device. We’re you hoping for a way to do an on-demand database export for backup purposes, or use an external database of your own?
