The only thing I know is that flash failed (it says “flash failed, hope you enjoyed”). I’m in Win10 trying to create a bootable linuxlite USB stick. I searched this blog but did not read the 100+ search results.
It leaves me with a USB whith RAW fs. If I try to format to FAT32 again, I get “cannot determine nr of sectors”. I tried with 3 different sticks that were all empty and working before using etcher. I looked for some logfile but could not find, ctrl+shift+i did not help me… Please advise !
I found the article “www.balena.io/blog/did-etcher-break-my-usb-sd-card/” but the “broken” USB is not listed when I ask “list disk”. I could reformat to FAT32 in windows which makes it possible again to use the USB for storage (I tested) but even then it is not listed in “list disk”. So I can’t do what is said in that article.
